09-26-2022, 02:03 PM
Made_for_ESPHome_KC868-E16T.zip (Size: 887 bytes / Downloads: 863)
platform: ESP32
sda: 16
scl: 15
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
# Optional manual IP
# manual_ip:
# static_ip: 192.168.1.199
# gateway: 192.168.1.1
# subnet: 255.255.255.0
address: 0x21
address: 0x25
address: 0x22
address: 0x24
# Individual outputs
pcf8574: pcf8574_hub_out_1
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
pcf8574: pcf8574_hub_out_2
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
pcf8574: pcf8574_hub_in_1
number: 4
number: 5
number: 6
number: 7
pcf8574: pcf8574_hub_in_2
number: 4
number: 5
number: 6
number: 7
