KC868-A16 with IDE 2.3.4
After installation of IDE 2.3.4 on Windows 11 and inserted the link "https://dl.espressif.com/dl/package_esp32_index.json" in the preferences  The "esp32 by espressif Systems 3.1.1" is installed
I see only under "Tools" the board "esp32"
Under sep32 I see a lot of modules but no ESP32 Arduino Module. I cannot connect via the Com3 to my KC868-A16 REV:1.6
Can anyone help me with installation of the correct board and module to get the communication with my KC868
Great thanks
Theo
board type: chose ESP32 DEV or Nodemcu-32s
I found the ESP32 and Nodemcu-32S.
I uploaded a simple sketch
"void setup() {
pinMode(3,OUTPUT);
digitalWrite(3,HIGH);
But still no LED on Dig out 3
When debugging , this is the reply:
Waiting for gdb server to start...[2025-03-10T16:26:28.761Z] SERVER CONSOLE DEBUG: onBackendConnect: gdb-server session connected. You can switch to "DEBUG CONSOLE" to see GDB interactions.
"C:\\Users\\herma\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\openocd-esp32\\v0.12.0-esp32-20241016/bin/openocd" -c "gdb_port 50000" -c "tcl_port 50001" -c "telnet_port 50002" -s "c:\\Users\\herma\\Documents\\Arduino\\sketch_mar1b" -f "C:/Users/herma/AppData/Local/Programs/Arduino IDE/resources/app/plugins/cortex-debug/extension/support/openocd-helpers.tcl" -f board/esp32-wrover-kit-3.3v.cfg
Open On-Chip Debugger v0.12.0-esp32-20241016 (2024-10-16-14:17)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
DEPRECATED! use 'gdb port', not 'gdb_port'
DEPRECATED! use 'tcl port' not 'tcl_port'
CDRTOSConfigure
Info : Listening on port 50001 for tcl connections
Info : Listening on port 50002 for telnet connections
Error: unable to open ftdi device with description '*', serial '*' at bus location '*'
C:/Users/herma/AppData/Local/Arduino15/packages/esp32/tools/openocd-esp32/v0.12.0-esp32-20241016/bin/../share/openocd/scripts/target/esp_common.cfg:9: Error:
at file "C:/Users/herma/AppData/Local/Arduino15/packages/esp32/tools/openocd-esp32/v0.12.0-esp32-20241016/bin/../share/openocd/scripts/target/esp_common.cfg", line 9
[2025-03-10T16:26:29.291Z] SERVER CONSOLE DEBUG: onBackendConnect: gdb-server session closed
GDB server session ended. This terminal will be reused, waiting for next session to start...
Would appreciate your reply , Thanks
Theo
I am able to use now the Nodemcu-32S and the ESP32 Dev Module but still no response on the KC868-A16 board, (LED)
See attached here the error file after debugging.
Thanks in advance for your reply.
Theo Smile
.docx   Debugging results.docx (Size: 14.3 KB / Downloads: 827)
take a screen photo what board you selected.
(03-10-2025, 10:55 PM)admin Wrote: take a screen photo what board you selected.
Thanks for the fast reply Smile
See attached the board I selected .
I hope this can help.
B. regards
Theo
it's correct, you can test with our demo sample code firstly, not use your own code.
Thanks for your reply,
Could you send me your demo sample code,I would appreciate
B. regards,
Theo
https://www.kincony.com/forum/forumdisplay.php?fid=25
Thanks, I already installed the PCF8574 library from Renzo Mischianti and copied his sample code.
But with no results.
After debugging I alway see in the "Notifications" OpenOCD: GDB Server Quit unexpected.
Attached you find the screenshot:
B. regards,
Theo
