02-15-2025, 03:01 AM
friendly_name: a16v3
platformio_options:
board_build.flash_mode: dio
board: esp32-s3-devkitc-1
type: esp-idf
type: W5500
clk_pin: GPIO42
mosi_pin: GPIO43
miso_pin: GPIO44
cs_pin: GPIO15
interrupt_pin: GPIO2
reset_pin: GPIO1
- id: bus_a
sda: 9
scl: 10
frequency: 400kHz
address: 0x24
address: 0x25
address: 0x21
address: 0x22
uart:
- id: uart_1
baud_rate: 9600
debug:
direction: BOTH
dummy_receiver: true
after:
timeout: 10ms
tx_pin: 16
rx_pin: 17
- platform: uart
uart_id: uart_1
pcf8574: pcf8574_hub_out_1
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
pcf8574: pcf8574_hub_out_2
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
pcf8574: pcf8574_hub_in_1
number: 4
number: 5
number: 6
number: 7
pcf8574: pcf8574_hub_in_2
number: 4
number: 5
number: 6
number: 7
number: 47
number: 48
number: 38
number: 39
number: 40
number: 41
- platform: adc
pin: 4
name: "A16v3 A1 Voltage"
update_interval: 5s
attenuation: 11db
filters:
- lambda:
if (x >= 3.11) {
return x * 1.60256;
} else if (x <= 0.15) {
return 0;
} else {
return x * 1.51;
- platform: adc
pin: 6
name: "A16v3 A2 Voltage"
update_interval: 5s
attenuation: 11db
filters:
# - multiply: 1.51515
- lambda:
if (x >= 3.11) {
return x * 1.60256;
return 0;
} else {
return x * 1.51;
- platform: adc
pin: 7
name: "A16v3 A3 Current"
update_interval: 5s
unit_of_measurement: mA
attenuation: 11db
filters:
- multiply: 6.66666666
- platform: adc
pin: 5
name: "A16v3 A4 Current"
update_interval: 5s
attenuation: 11db
filters:
web_server:
port: 80
# font:
# - file: "gfonts://Roboto"
# id: roboto
# size: 20
# display:
# - platform: ssd1306_i2c
# i2c_id: bus_a
# model: "SSD1306 128x64"
# address: 0x3C
# lambda: |-
# it.printf(0, 0, id(roboto), "A16v3");
A16v3-ESPHome.txt (Size: 7.81 KB / Downloads: 1,199)
