platform: ESP32
platformio_options:
board_build.extra_flags:
# WIFI_CONTROL_SELF_MODE = 0
# WIFI_CONTROL_SELF_MODE = 1
- "-DWIFI_CONTROL_SELF_MODE=0"
external_components:
- source:
type: git
ref: v1.1.0
uart:
tx_pin: 33
rx_pin: 14
baud_rate: 9600
tuya_wifi_mcu:
# tuya mcu product id
product_id: tfj1dtlneyxp5uya
uart_id: tuya_mcu_uart
wifi_reset_pin: 5
wifi_led_pin: 12
sda: 16
scl: 15
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
address: 0x21
address: 0x25
address: 0x22
address: 0x24
# Individual outputs
pcf8574: pcf8574_hub_out_1
mode: OUTPUT
- platform: tuya_wifi_mcu
dp_id: 1
# hide from homeassistant ui
internal: true
bind_switch_id: "e16t_output1"
mode: OUTPUT
dp_id: 2
internal: true
bind_switch_id: "e16t_output2"
mode: OUTPUT
dp_id: 3
internal: true
bind_switch_id: "e16t_output3"
mode: OUTPUT
dp_id: 4
internal: true
bind_switch_id: "e16t_output4"
number: 4
mode: OUTPUT
dp_id: 5
internal: true
bind_switch_id: "e16t_output5"
number: 5
mode: OUTPUT
dp_id: 6
internal: true
bind_switch_id: "e16t_output6"
number: 6
mode: OUTPUT
dp_id: 101
internal: true
bind_switch_id: "e16t_output7"
number: 7
mode: OUTPUT
dp_id: 102
internal: true
bind_switch_id: "e16t_output8"
pcf8574: pcf8574_hub_out_2
mode: OUTPUT
dp_id: 103
internal: true
bind_switch_id: "e16t_output9"
mode: OUTPUT
dp_id: 104
internal: true
bind_switch_id: "e16t_output10"
mode: OUTPUT
dp_id: 105
internal: true
bind_switch_id: "e16t_output11"
mode: OUTPUT
dp_id: 106
internal: true
bind_switch_id: "e16t_output12"
number: 4
mode: OUTPUT
dp_id: 107
internal: true
bind_switch_id: "e16t_output13"
number: 5
mode: OUTPUT
dp_id: 108
internal: true
bind_switch_id: "e16t_output14"
number: 6
mode: OUTPUT
dp_id: 109
internal: true
bind_switch_id: "e16t_output15"
number: 7
mode: OUTPUT
dp_id: 110
internal: true
bind_switch_id: "e16t_output16"
pcf8574: pcf8574_hub_in_1
name: e16t DI01 Tuya
dp_id: 111
bind_binary_sensor_id: e16t_input1
internal: true
name: e16t DI02 Tuya
dp_id: 112
bind_binary_sensor_id: e16t_input2
internal: true
name: e16t DI03 Tuya
dp_id: 113
bind_binary_sensor_id: e16t_input3
internal: true
name: e16t DI04 Tuya
dp_id: 114
bind_binary_sensor_id: e16t_input4
internal: true
number: 4
name: e16t DI05 Tuya
dp_id: 115
bind_binary_sensor_id: e16t_input5
internal: true
number: 5
name: e16t DI06 Tuya
dp_id: 116
bind_binary_sensor_id: e16t_input6
internal: true
number: 6
name: e16t DI07 Tuya
dp_id: 117
bind_binary_sensor_id: e16t_input7
internal: true
number: 7
name: e16t DI08 Tuya
dp_id: 118
bind_binary_sensor_id: e16t_input8
internal: true
pcf8574: pcf8574_hub_in_2
name: e16t DI09 Tuya
dp_id: 119
bind_binary_sensor_id: e16t_input9
internal: true
name: e16t DI10 Tuya
dp_id: 120
bind_binary_sensor_id: e16t_input10
internal: true
name: e16t DI11 Tuya
dp_id: 121
bind_binary_sensor_id: e16t_input11
internal: true
name: e16t DI12 Tuya
dp_id: 122
bind_binary_sensor_id: e16t_input12
internal: true
number: 4
name: e16t DI13 Tuya
dp_id: 123
bind_binary_sensor_id: e16t_input13
internal: true
number: 5
name: e16t DI14 Tuya
dp_id: 124
bind_binary_sensor_id: e16t_input14
internal: true
number: 6
name: e16t DI15 Tuya
dp_id: 125
bind_binary_sensor_id: e16t_input15
internal: true
number: 7
name: e16t DI16 Tuya
dp_id: 126
bind_binary_sensor_id: e16t_input16
internal: true
api:download yaml file:
E16T-HA-Tuya.txt (Size: 11.91 KB / Downloads: 395)
