  • 1 Vote(s) - 5 Average
"KCS" v3.8.0 firmware BIN file download
v3.8.0 improvement:
1. IFTTT IF condition support TCP,UDP,RS485,RS232 ANSI-String or HEX command.
2. support SIM7600 4G module make CALL, send SMS and receive SMS by MQTT.
3. support SIM7600 4G module work as GSM bridge with RXD,TXD free GPIO pins.
4. support option for add sensor value to SSD1306 LCD display.
5. fixed bug with monitor "auto refresh" function.
6. fixed bug with sensor data auto upload to MQTT.
.zip   KCS_A6V3_V3.8.0.zip (Size: 1.01 MB / Downloads: 854)
.zip   KCS_A16V3_V3.8.0.zip (Size: 1.08 MB / Downloads: 988)
.zip   KCS_A32PRO_V3.8.0.zip (Size: 1.05 MB / Downloads: 701)
.zip   KCS_AG8_V3.8.0.zip (Size: 1.04 MB / Downloads: 743)
.zip   KCS_B16_V3.8.0.zip (Size: 1.07 MB / Downloads: 780)
.zip   KCS_B16M_V3.8.0.zip (Size: 1.07 MB / Downloads: 737)
.zip   KCS_F16_V3.8.0.zip (Size: 1.08 MB / Downloads: 740)
.zip   KCS_F24_V3.8.0.zip (Size: 1.08 MB / Downloads: 780)
.zip   KCS_G1_V3.8.0.zip (Size: 1.03 MB / Downloads: 764)
.zip   KCS_T16M_V3.8.0.zip (Size: 1.02 MB / Downloads: 863)
Lightbulb
hi its possibly to make import or export backup to the configuration file ?
easiest way to export/import everything from ESP32 - CLONE/BACKUP Tool
https://youtu.be/pUWbxX2K58A
Heart
(04-12-2025, 11:38 AM)admin Wrote: easiest way to export/import everything from ESP32 - CLONE/BACKUP Tool
thanks i wil tray it
but its gona be nice if you can do it directly from the controller G1, like import/export configurations file
Hi
There is an issue with the automation of the trigger, when the trigger is activated it activates the automation, in my opinion a time condition should be added to the duration of the action to produce a more reliable trigger.
I am attaching a picture that I think should be added such a function as in HA.
Do you mean that a specific duration is required as a judgment when the conditions are met?
yes
like that
if:
- condition: state
entity_id: sensor.temperature
state: "27"
for:
hours: 0
minutes: 1
seconds: 0
then:
- action: notify.send_message
metadata: {}
data: {}
target:
entity_id: my_phone
i see, will save your suggestion.
Thumbs Up
(04-19-2025, 12:49 AM)admin Wrote: i see, will save your suggestion.
please let me know if you make update
Hello
I am building a temperature controller from the g1. My intention is to use this controller both as a controller that works alone with internal automations, and also to connect it to a home assistant.
After several tests I have performed, I have discovered several problems.
1. When connecting sensor 5 to gpio number 5, there is no response from the sensor.
2. Today I am only connecting 6 temperatures, I would be happy if there was a possibility to use all gpio, 4,5,6,7,13,14,15,16,17,40 and add them to the table.
3. I discovered a serious problem in interfacing to ha mqtt, when the controller is connected everything works fine.
But if the controller is disconnected from the power supply, the values still continue to appear as available in Home Assistant for an unlimited time, and this is really wrong. The system should report that the controller is no longer available, otherwise there is no real indication between the controller and the entire system. I also checked the issue with an mqtt broker without Home Assistant. It behaves the same way. This situation should not happen. This controller is supposed to be super reliable, especially since it is a temperature system for refrigerators with messaging and cellular communication.
4. There are measurement differences of 2 degrees between the temperature sensors even though they are in exactly the same place next to each other (if this can be made precise, it would be great).
