Threads: 2
Hi. There are of the my IDE code:
include <PCF8574.h>
#include <Wire.h>
#define SDA_PIN 4 // GPIO номер SDA
#define SCL_PIN 15 // GPIO номер SCL
Wire.begin(SDA_PIN, SCL_PIN); // Задали новые контакты для I²C
// Инициализируем I²C
Serial.begin(115200); // Инициализируем последовательный порт
while (!Serial); // Ждем открытия порта
Serial.println("\n\n--- I²C Scanner ---");
byte error, address;
int nDevicesFound = 0;
Serial.println("Scaning...");
for (address = 1; address < 127; address++ ) {
Wire.beginTransmission(address);
error = Wire.endTransmission();
if (error == 0) {
Serial.print("Device found at address: 0x");
if (address < 16) {
Serial.print("0");
Serial.println(address, HEX);
nDevicesFound++;
else if (error == 4) {
Serial.print("Unknown error at address: 0x");
if (address < 16) {
Serial.print("0");
if (nDevicesFound == 0) {
Serial.println("No I²C devices found.\n");
} else {
Serial.println("Scan complete.\n");
delay(5000); // Повторяем проверку каждые 5 секунд
Where it any mistake?
Threads: 1,385
please download KCS v2 firmware to test your board firstly.
if KCS v2 firmware work well, that means hardware is well, you need to check your software system.
Threads: 1,385
after you downloaded KCS v2 firmware, login by web browser, click "monitor" webpage, turn on/off relay button ico, relay can't work , right?
Threads: 1,385
take a photo of your PCB board.
Threads: 1,385
what power supply you are using? suggest use DC12V 2A. suggest you change a new power supply for a testing.
