Troubles using I2C/IIC bus
#11
you just need to install PCF8574 library.
.zip   PCF8574_library.zip (Size: 23.8 MB / Downloads: 419)
Hi. There are of the my IDE code:
include <PCF8574.h>
#include <Wire.h>
#define SDA_PIN 4 // GPIO номер SDA
#define SCL_PIN 15 // GPIO номер SCL
Wire.begin(SDA_PIN, SCL_PIN); // Задали новые контакты для I²C
// Инициализируем I²C
Serial.begin(115200); // Инициализируем последовательный порт
while (!Serial); // Ждем открытия порта
Serial.println("\n\n--- I²C Scanner ---");
byte error, address;
int nDevicesFound = 0;
Serial.println("Scaning...");
for (address = 1; address < 127; address++ ) {
Wire.beginTransmission(address);
error = Wire.endTransmission();
if (error == 0) {
Serial.print("Device found at address: 0x");
if (address < 16) {
Serial.print("0");
Serial.println(address, HEX);
nDevicesFound++;
else if (error == 4) {
Serial.print("Unknown error at address: 0x");
if (address < 16) {
Serial.print("0");
if (nDevicesFound == 0) {
Serial.println("No I²C devices found.\n");
} else {
Serial.println("Scan complete.\n");
delay(5000); // Повторяем проверку каждые 5 секунд
Where it any mistake?
What does  the problem at  yours demo Relays code?
May be the KC-868-A6 Board  is defective?
please download KCS v2 firmware to test your board firstly.
if KCS v2 firmware work well, that means hardware is well, you need to check your software system.
(06-30-2025, 11:20 PM)admin Wrote: please download KCS v2 firmware to test your board firstly.
Dear Admin!
I have already installed the KSV firmware on my board several times.The version of the my  Firmware is  KC868_A6-v2.2.14.bin.
See  you the attachment.
After installation   this firmware I2C and relays does not wort on my Board too!
after you downloaded KCS v2 firmware, login by web browser, click "monitor" webpage, turn on/off relay button ico, relay can't work , right?
Dear,Admin!
This is incredible!!
The KC 868 Board worked. But in the Monitor Menu there is NO RELAY,  Please see screenshot
take a photo of your PCB board.
(07-02-2025, 10:44 AM)admin Wrote: take a photo of your PCB board.
There is of Photo my Board
what power supply you are using? suggest use DC12V 2A. suggest you change a new power supply for a testing.
