KC868-A6v3 ESPHome yaml for home assistant
  friendly_name: a6v3
  board: esp32-s3-devkitc-1
    type: arduino
wifi:
  ssid: "KinCony"
  password: "a12345678"
  ap:
    ssid: "A6 Fallback Hotspot"
    password: "GLdHSsZr1p96"
captive_portal:
  sda: 12
  scl: 11
    address: 0x24
    address: 0x22
uart:
  - id: uart_1    #RS485
    baud_rate: 9600
    debug:
      direction: BOTH
      dummy_receiver: true
      after:
        timeout: 10ms
    tx_pin: 17
    rx_pin: 18
  - id: uart_2    #RS232
    baud_rate: 9600
    debug:
      direction: BOTH
      after:
        timeout: 10ms
    tx_pin: 9
    rx_pin: 10
      pcf8574: pcf8574_hub_out_1
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
  - platform: uart
    uart_id: uart_1
  - platform: uart
    uart_id: uart_2
    data: [0x55, 0x66, 0x77, 0x88, 0x99]
      pcf8574: pcf8574_hub_in_1
      number: 4
      number: 5
##pull-up resistance on PCB
      number: 15
      number: 16
  - platform: adc
    pin: 4
    name: "A6v3 A1 Voltage"
    update_interval: 5s
    attenuation: 11db
    filters:
      - lambda:
          if (x >= 3.11) {
            return x * 1.60256;
          } else if (x <= 0.15) {
            return 0;
          } else {
            return x * 1.51;
  - platform: adc
    pin: 5
    name: "A6v3 A2 Voltage"
    update_interval: 5s
    attenuation: 11db
    filters:
      # - multiply: 1.51515
      - lambda:
          if (x >= 3.11) {
            return x * 1.60256;
            return 0;
          } else {
            return x * 1.51;
  - platform: adc
    pin: 6
    name: "A6v3 A3 Current"
    update_interval: 5s
    unit_of_measurement: mA
    attenuation: 11db
    filters:
      - multiply: 6.66666666
  - platform: adc
    pin: 7
    name: "A6v3 A4 Current"
    update_interval: 5s
    attenuation: 11db
    filters:
font:
  - file: "gfonts://Roboto"
display:
  - platform: ssd1306_i2c
    i2c_id: bus_a
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
      it.printf(0, 0, id(roboto), "KinCony A6v3");
gp8403:
  voltage: 10V
output:
  - platform: gp8403
    gp8403_id: my_gp8403
    channel: 0
  - platform: gp8403
    channel: 1
light:
  - platform: monochromatic
    output: gp8403_output_1
    output: gp8403_output_2
web_server:
  port: 80
esphome yaml file download:
.txt   A6v3-HA.txt (Size: 5.11 KB / Downloads: 894)
It works perfectly thank you.Can you help me because my ds18b20 device is not showing up.I have 2 of them connected to the panel.
take a photo, how you connect with KC868-A6v3 board. it should work with ESPHome yaml, just add DS18B20 code.
https://esphome.io/components/sensor/dallas_temp.html
Could you check if my code, added to your code for this board, is causing any Wi-Fi issues?
In the ESP32 version, it caused a Wi-Fi conflict and wouldn't connect to Home Assistant. You can adapt the pins to the ESP32 S3 board.
Thanks for checking.
uart:
rx_pin: 1
tx_pin: 3
baud_rate: 9600
modbus:
one_wire:
#Zółty przewód
pin: 18
#Pomarańczowy przewód
pin: 17
time:
- platform: homeassistant
on_time:
- seconds: 1
minutes: 0
hours: 0
then:
- lambda: |-
id(daily_energy_total) = 0.0;
# id(last_pzem_energy) = id(PC_PkWh).state;
# Reset miesięcznego zużycia pierwszego dnia miesiąca o 00:00:01
- seconds: 1
minutes: 0
hours: 0
days_of_month: 1
then:
- lambda: |-
id(monthly_energy_total) = 0.0;
- platform: sntp
timezone: Europe/Warsaw
servers:
- 0.pl.pool.ntp.org
- 1.pl.pool.ntp.org
- 2.pl.pool.ntp.org
- platform: template
name: "Czas od ostatniego włączenia"
accuracy_decimals: 0
unit_of_measurement: "min"
update_interval: 1s
lambda: |-
auto now = id(esp_time).now().timestamp;
if (id(last_on_time) == 0) {
return 0;
} else {
return (now - id(last_on_time)) / 60;
name: "Dzienne zużycie energii"
unit_of_measurement: "kWh"
accuracy_decimals: 2
update_interval: 1s
lambda: |-
return id(daily_energy_total) / 1000.0;
# Miesięczny licznik energii
name: "Miesięczne zużycie energii"
update_interval: 1s
lambda: |-
return id(monthly_energy_total) / 1000.0;
name: "Podniesienie temperatury przez GWC"
unit_of_measurement: "°C"
accuracy_decimals: 1
lambda: |-
// Jeśli GWC Powietrze jest włączone, zwróć 0
if (id(Pozycja_GWC_Powietrze).state) {
return 0.0;
// Jeśli GWC Ziemia nie jest włączone, zwróć 0 (opcjonalne zabezpieczenie)
if (!id(Pozycja_GWC_Ziemia).state) {
return 0.0;
return id(CZ).state - id(temperatura_zew_HA).state;
update_interval: 15s
name: "Koszt całkowity"
lambda: |-
// Pobierz wartość zużycia energii
float A = id(PC_PkWh).state;
// Oblicz koszt całkowity
return A * 1.0;
unit_of_measurement: "PLN"
- platform: wifi_signal
name: "Moc sygnału Wi-Fi"
update_interval: 60s # Aktualizacja co minutę
# MODUŁ PZEM 004 T MIERNIK ENERGII
- platform: pzemac
current:
name: "PZEM-004T V3 Current"
voltage:
name: "PZEM-004T V3 Voltage"
energy:
name: "PZEM-004T V3 Energy"
unit_of_measurement: Wh
power:
name: "PZEM-004T V3 Power"
frequency:
name: "PZEM-004T V3 Frequency"
power_factor:
name: "PZEM-004T V3 Power Factor"
update_interval: 1s
- platform: pzemac
energy:
name: "PZEM-004T V3 Energy kWh"
unit_of_measurement: kWh
filters:
# Multiplication factor from Wh to kWh is 0.001
- multiply: 0.001
power:
name: "PZEM-004T V3 Power kWh"
filters:
- multiply: 0.001
update_interval: 1s
- platform: dht
model: AUTO_DETECT
pin: 15
temperature:
humidity:
update_interval: 15min
# CZUJNIK TEMPERATURY REKUPERATOR
- platform: dallas_temp
one_wire_id: Rekuperator
address: 0x0900000083a04028
filters:
multiply: 1.05
address: 0x350000006a8f2628
filters:
multiply: 0.99
address: 0xdf00000085c2fd28
filters:
multiply: 1.04
address: 0xe200000069f46728
filters:
multiply: 1.05
#CZUJNIK TEMPERATURY NAGRZEWNICY
one_wire_id: Nagrzewnica
address: 0xde0000008300b928
filters:
multiply: 0.99
address: 0x5200000083035c28
filters:
multiply: 1.01
address: 0xc000000082fc1428
filters:
multiply: 0.993
address: 0x170000008807d328
address: 0x93000000854b3828
name: "Temperatura Kompresor"
filters:
multiply: 0.99
if your yaml have issue. you can download KCS v3 firmware to esp32-s3. enable mqtt auto discovery option for home assistant. So that all hardware resource will integrate to home assistant easily.
You don't understand the questions. The ten additional codes added to your code on the ESP32 board are causing a Wi-Fi conflict. I'm guessing the data packets are too large for the ESP32. Now I want to buy a board with an ESP32 S3 module from you and I'm curious if the same problem might occur. If I encounter problems that don't make sense, then I'll be buying something that doesn't meet my requirements. I'd have to check if the problem persists before purchasing.
i think software will not conflict wifi. maybe you can check hardware wire. if you disconnect with the meter, whether work well.
