Threads: 4
My KC868-A16 stopped working with ESPHome. There is power, but there is no network connection. I can still flash directly with USB-C port.
Here is the esphome logs:
logs.txt (Size: 60.45 KB / Downloads: 264)
logs (1).txt (Size: 28.23 KB / Downloads: 177)
Threads: 1,305
if you download KCS v2 firmware, whether work well?
Threads: 1,305
if ethernet can't work, can you re solder the LAN8720A chip? it beside ethernet port.
Threads: 1,305
after downloaded KCS v2 firmware, WIFI also can't work?
Threads: 1,305
take photo of your setting of ESP download tool i want to see how you download KCS v2 firmware.
Threads: 1,305
after downloaded firmware, MUST re power on of your board. then use ethernet cable firstly, login by web browser, set the wifi to STA mode, input your router's ssid and password.
