04-20-2025, 05:46 AM
friendly_name: a2v3
board: esp32-s3-devkitc-1
type: arduino
type: W5500
clk_pin: GPIO42
mosi_pin: GPIO43
miso_pin: GPIO44
cs_pin: GPIO41
interrupt_pin: GPIO2
reset_pin: GPIO1
- id: bus_a
sda: 48
scl: 47
frequency: 400kHz
uart:
- id: uart_1
baud_rate: 9600
debug:
direction: BOTH
dummy_receiver: true
after:
timeout: 10ms
tx_pin: 7
rx_pin: 15
- id: uart_sim7600
baud_rate: 115200
debug:
direction: BOTH
after:
timeout: 10ms
sequence:
tx_pin: 10
rx_pin: 9
pin: 40
pin: 39
- platform: uart
uart_id: uart_1
- platform: uart
uart_id: uart_sim7600
data: "AT+CGSN\r\n" # read 4G SIM7600 ID
number: 16
number: 17
number: 18
number: 8
number: 4
mode:
input: true
pullup: true
number: 5
mode:
input: true
pullup: true
number: 6
mode:
input: true
pullup: true
number: 38
mode:
input: true
pullup: true
web_server:
port: 80
font:
- file: "gfonts://Roboto"
display:
- platform: ssd1306_i2c
i2c_id: bus_a
model: "SSD1306 128x64"
address: 0x3C
lambda: |-
it.printf(0, 0, id(roboto), "A2v3");
A2v3-HA.txt (Size: 2.39 KB / Downloads: 367)
