Threads: 1,560
not suggest use by this way. the current is low, not suitable for extend LED.
Threads: 9
Could you use it to power something like an LM3909 (if you can still find one), which draws something like 0.5mA?
Threads: 3
I would love to see the HA2 485 module be able to use dimming function over 485 , e.g. hold to dim up or dim down
Threads: 1,560
HAv2 with which dimmer controller?
Threads: 1,560
09-10-2025, 12:46 AM
(This post was last modified: 09-10-2025, 12:47 AM by admin.)
HAv2 will support new dimmer board - KinCony DM16 dimmer controller in future.
Threads: 1
I use the KC868-AP PWM Dimmer to control my RGBW LED lamps, an RS485 sensor, and one relay device. It would be great to add 0–10V outputs to it, if possible. It would also be great to replace the plastic cover with an aluminum one.
Threads: 1,560
now the version DM16 controller is released, it's aluminum case.
