N10 configure yaml for ESPhome
  friendly_name: n10
  board: esp32-s3-devkitc-1
    type: arduino
  # baud_rate: 0
ota:
  platform: esphome
  type: W5500
  clk_pin: GPIO42
  mosi_pin: GPIO43
  miso_pin: GPIO44
  cs_pin: GPIO41
  interrupt_pin: GPIO2
  reset_pin: GPIO1
uart:
  rx_pin: 9
  tx_pin: 10
  baud_rate: 115200
  stop_bits: 1
  data_bits: 8
  parity: NONE
web_server:
  port: 80
text_sensor:
  - platform: ethernet_info
    ip_address:
      name: ESP IP Address
      address_0:
        name: ESP IP Address 0
      address_1:
        name: ESP IP Address 1
      address_2:
        name: ESP IP Address 2
      address_3:
        name: ESP IP Address 3
      address_4:
        name: ESP IP Address 4
    dns_address:
      name: ESP DNS Address
    mac_address:
      name: ESP MAC Address
font:
  - file: "gfonts://Roboto"
  sda: 18
  scl: 17
display:
  - platform: ssd1306_i2c
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
      it.printf(0, 15, id(roboto), "IP: %s", id(eth_ip).state.c_str());
modbus:
modbus_controller:
  - address: 1
    update_interval: 5s
  - platform: modbus_controller
    address: 100
    register_type: holding
    unit_of_measurement: A
    device_class: current
    accuracy_decimals: 3
    value_type: U_DWORD_R
    filters:
      - multiply: 0.001
    address: 102
    filters:
      - multiply: 0.001
    address: 104
    filters:
      - multiply: 0.001
    address: 106
    filters:
      - multiply: 0.001
    address: 108
    filters:
      - multiply: 0.001
    address: 110
    filters:
      - multiply: 0.001
    address: 112
    filters:
      - multiply: 0.001
    address: 114
    filters:
      - multiply: 0.001
    address: 116
    filters:
      - multiply: 0.001
    address: 118
    filters:
      - multiply: 0.001
    address: 120
    unit_of_measurement: W
    device_class: power
    accuracy_decimals: 1
    filters:
      - multiply: 0.1
    address: 122
    device_class: power
    filters:
      - multiply: 0.1
    address: 124
    device_class: power
    filters:
      - multiply: 0.1
    address: 126
    device_class: power
    filters:
      - multiply: 0.1
    address: 128
    device_class: power
    filters:
      - multiply: 0.1
    address: 130
    device_class: power
    filters:
      - multiply: 0.1
    address: 132
    device_class: power
    filters:
      - multiply: 0.1
    address: 134
    device_class: power
    filters:
      - multiply: 0.1
    address: 136
    device_class: power
    filters:
      - multiply: 0.1
    address: 138
    device_class: power
    filters:
      - multiply: 0.1
    state_class: total_increasing
    device_class: energy
    address: 140
    unit_of_measurement: kWh
    address: 142
    address: 144
    address: 146
    address: 148
    address: 150
    address: 152
    address: 154
    address: 156
    address: 158
    address: 160
    address: 162
    unit_of_measurement: V
    device_class: voltage
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 163
    unit_of_measurement: Hz
    device_class: frequency
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 164
    unit_of_measurement: °C
    device_class: temperature
    value_type: FP32_R
yaml download:
.txt   N10-HA.txt (Size: 10.03 KB / Downloads: 426)
No values in n10_1_energy_*
What could be the problem?
operating time of the device with a load of more than 24 hours
[16:24:12.755][D][modbus_controller.sensor:025]: Sensor new state: 126.00
[16:24:12.759][D][sensor:129]: 'bl0910_1_current_1' >> 0.126 A
[16:24:12.764][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:12.769][D][sensor:129]: 'bl0910_1_current_2' >> 0.000 A
[16:24:12.773][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:12.778][D][sensor:129]: 'bl0910_1_current_3' >> 0.000 A
[16:24:12.783][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:12.788][D][sensor:129]: 'bl0910_1_current_4' >> 0.000 A
[16:24:12.792][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:12.797][D][sensor:129]: 'bl0910_1_current_5' >> 0.000 A
[16:24:12.802][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:12.806][D][sensor:129]: 'bl0910_1_current_6' >> 0.000 A
[16:24:12.811][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:12.816][D][sensor:129]: 'bl0910_1_current_7' >> 0.000 A
[16:24:12.821][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:12.826][D][sensor:129]: 'bl0910_1_current_8' >> 0.000 A
[16:24:12.830][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:12.835][D][sensor:129]: 'bl0910_1_current_9' >> 0.000 A
[16:24:12.840][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:12.844][D][sensor:129]: 'bl0910_1_current_10' >> 0.000 A
[16:24:12.850][D][modbus_controller.sensor:025]: Sensor new state: 131.00
[16:24:12.855][D][sensor:129]: 'bl0910_1_power_1' >> 13.1 W
[16:24:12.859][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:12.864][D][sensor:129]: 'bl0910_1_power_2' >> 0.0 W
[16:24:12.869][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:12.874][D][sensor:129]: 'bl0910_1_power_3' >> 0.0 W
[16:24:12.878][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:12.883][D][sensor:129]: 'bl0910_1_power_4' >> 0.0 W
[16:24:12.888][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:12.893][D][sensor:129]: 'bl0910_1_power_5' >> 0.0 W
[16:24:12.898][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:12.903][D][sensor:129]: 'bl0910_1_power_6' >> 0.0 W
[16:24:12.907][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:12.912][D][sensor:129]: 'bl0910_1_power_7' >> 0.0 W
[16:24:12.917][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:12.922][D][sensor:129]: 'bl0910_1_power_8' >> 0.0 W
[16:24:12.927][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:12.932][D][sensor:129]: 'bl0910_1_power_9' >> 0.0 W
[16:24:12.936][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:12.941][D][sensor:129]: 'bl0910_1_power_10' >> 0.0 W
[16:24:12.946][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:12.951][D][sensor:129]: 'bl0910_1_energy_1' >> 0.0 kWh
[16:24:12.956][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:12.961][D][sensor:129]: 'bl0910_1_energy_2' >> 0.0 kWh
[16:24:12.965][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:12.971][D][sensor:129]: 'bl0910_1_energy_3' >> 0.0 kWh
[16:24:12.975][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:12.980][D][sensor:129]: 'bl0910_1_energy_4' >> 0.0 kWh
[16:24:12.985][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:12.990][D][sensor:129]: 'bl0910_1_energy_5' >> 0.0 kWh
[16:24:12.995][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:13.000][D][sensor:129]: 'bl0910_1_energy_6' >> 0.0 kWh
[16:24:13.005][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:13.009][D][sensor:129]: 'bl0910_1_energy_7' >> 0.0 kWh
[16:24:13.014][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:13.019][D][sensor:129]: 'bl0910_1_energy_8' >> 0.0 kWh
[16:24:13.024][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:13.029][D][sensor:129]: 'bl0910_1_energy_9' >> 0.0 kWh
[16:24:13.034][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:13.039][D][sensor:129]: 'bl0910_1_energy_10' >> 0.0 kWh
[16:24:13.043][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:13.048][D][sensor:129]: 'bl0910_1_energy_sum' >> 0.0 kWh
[16:24:13.054][D][modbus_controller.sensor:025]: Sensor new state: 21977.00
[16:24:13.058][D][sensor:129]: 'bl0910_1_voltage' >> 219.8 V
[16:24:13.063][D][modbus_controller.sensor:025]: Sensor new state: 4990.00
[16:24:13.069][D][sensor:129]: 'bl0910_1_frequency' >> 49.9 Hz
[16:24:13.073][D][modbus_controller.sensor:025]: Sensor new state: 32.88
[16:24:13.078][D][sensor:129]: 'bl0910_1_tps1' >> 32.9 °C
[16:24:17.785][D][modbus_controller.sensor:025]: Sensor new state: 121.00
[16:24:17.789][D][sensor:129]: 'bl0910_1_current_1' >> 0.121 A
[16:24:17.794][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:17.799][D][sensor:129]: 'bl0910_1_current_2' >> 0.000 A
[16:24:17.804][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:17.808][D][sensor:129]: 'bl0910_1_current_3' >> 0.000 A
[16:24:17.813][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:17.818][D][sensor:129]: 'bl0910_1_current_4' >> 0.000 A
[16:24:17.823][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:17.827][D][sensor:129]: 'bl0910_1_current_5' >> 0.000 A
[16:24:17.832][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:17.837][D][sensor:129]: 'bl0910_1_current_6' >> 0.000 A
[16:24:17.841][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:17.846][D][sensor:129]: 'bl0910_1_current_7' >> 0.000 A
[16:24:17.851][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:17.855][D][sensor:129]: 'bl0910_1_current_8' >> 0.000 A
[16:24:17.860][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:17.865][D][sensor:129]: 'bl0910_1_current_9' >> 0.000 A
[16:24:17.870][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:17.875][D][sensor:129]: 'bl0910_1_current_10' >> 0.000 A
[16:24:17.880][D][modbus_controller.sensor:025]: Sensor new state: 124.00
[16:24:17.885][D][sensor:129]: 'bl0910_1_power_1' >> 12.4 W
[16:24:17.890][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:17.894][D][sensor:129]: 'bl0910_1_power_2' >> 0.0 W
[16:24:17.899][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:17.904][D][sensor:129]: 'bl0910_1_power_3' >> 0.0 W
[16:24:17.909][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:17.914][D][sensor:129]: 'bl0910_1_power_4' >> 0.0 W
[16:24:17.919][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:17.924][D][sensor:129]: 'bl0910_1_power_5' >> 0.0 W
[16:24:17.928][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:17.934][D][sensor:129]: 'bl0910_1_power_6' >> 0.0 W
[16:24:17.938][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:17.943][D][sensor:129]: 'bl0910_1_power_7' >> 0.0 W
[16:24:17.948][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:17.953][D][sensor:129]: 'bl0910_1_power_8' >> 0.0 W
[16:24:17.958][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:17.963][D][sensor:129]: 'bl0910_1_power_9' >> 0.0 W
[16:24:17.967][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:17.972][D][sensor:129]: 'bl0910_1_power_10' >> 0.0 W
[16:24:17.978][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:17.984][D][sensor:129]: 'bl0910_1_energy_1' >> 0.0 kWh
[16:24:17.986][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:17.992][D][sensor:129]: 'bl0910_1_energy_2' >> 0.0 kWh
[16:24:17.997][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:18.002][D][sensor:129]: 'bl0910_1_energy_3' >> 0.0 kWh
[16:24:18.007][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:18.012][D][sensor:129]: 'bl0910_1_energy_4' >> 0.0 kWh
[16:24:18.016][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:18.021][D][sensor:129]: 'bl0910_1_energy_5' >> 0.0 kWh
[16:24:18.026][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:18.030][D][sensor:129]: 'bl0910_1_energy_6' >> 0.0 kWh
[16:24:18.035][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:18.040][D][sensor:129]: 'bl0910_1_energy_7' >> 0.0 kWh
[16:24:18.045][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:18.050][D][sensor:129]: 'bl0910_1_energy_8' >> 0.0 kWh
[16:24:18.055][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:18.060][D][sensor:129]: 'bl0910_1_energy_9' >> 0.0 kWh
[16:24:18.064][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:18.069][D][sensor:129]: 'bl0910_1_energy_10' >> 0.0 kWh
[16:24:18.074][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[16:24:18.080][D][sensor:129]: 'bl0910_1_energy_sum' >> 0.0 kWh
[16:24:18.084][D][modbus_controller.sensor:025]: Sensor new state: 21714.00
[16:24:18.089][D][sensor:129]: 'bl0910_1_voltage' >> 217.1 V
[16:24:18.094][D][modbus_controller.sensor:025]: Sensor new state: 4991.00
[16:24:18.099][D][sensor:129]: 'bl0910_1_frequency' >> 49.9 Hz
[16:24:18.104][D][modbus_controller.sensor:025]: Sensor new state: 32.25
[16:24:18.110][D][sensor:129]: 'bl0910_1_tps1' >> 32.2 °C
download newest ARM CPU firmware by RS485-USB adapter: https://www.kincony.com/forum/showthread.php?tid=8863
(02-20-2026, 02:03 AM)admin Wrote: download newest ARM CPU firmware by RS485-USB adapter: https://www.kincony.com/forum/showthread.php?tid=8863
The proposed method did not lead to the desired result
1.Updated the ARM firmware
2. replaced esphome with KSC
do you have downloaded newest KCS firmware?
https://www.kincony.com/forum/showthread.php?tid=8961
Thank you
no
curent KCS - v3.18.2
ok,
Installed v3.19.1, there are no obvious changes.
I'm waiting for the result to accumulate.
installed v3.19.1 (https://www.kincony.com/forum/attachment.php?aid=9072)
use large current load, such as 2000w load, maybe need about 30 minutes will have data.
(02-21-2026, 04:16 AM)admin Wrote: use large current load, such as 2000w load, maybe need about 30 minutes will have data.
Thank you.
Indeed, an increase in the electrical load led to the result.
The high discreteness of data transmission is sad.
