Threads: 1,560
Code: esphome:
friendly_name: HAv2
board: esp32-s3-devkitc-1
type: esp-idf
baud_rate: 0
type: W5500
clk_pin: GPIO42
mosi_pin: GPIO43
miso_pin: GPIO44
cs_pin: GPIO41
interrupt_pin: GPIO2
reset_pin: GPIO1
external_components:
- source:
type: git
url: https://github.com/hzkincony/esphome-kc868-ha
ref: v3.0.1
uart:
- id: myuart1
tx_pin: 16
rx_pin: 17
baud_rate: 9600
debug:
direction: BOTH
dummy_receiver: false
kc868_ha:
# The binary_sensor corresponds to the state changes generated by K1~K6 on the KC868 HA board
# bind_output is required. Corresponds to the BindOutput parameter in HA485_Ctrl software
# Other parameters refer to: https://esphome.io/components/binary_sensor/index.html
- platform: kc868_ha
target_relay_controller_addr: 1 # Default value is 1, corresponds to the Target Relay Controller Addr parameter in HA485_Ctrl software
switch_adapter_addr: 10 # Default value is 10, corresponds to the Switch Adapter Addr parameter in HA485_Ctrl software
bind_output: 1 # Corresponds to the BindOutput parameter in HA485_Ctrl software
bind_output: 2
bind_output: 3
bind_output: 4
bind_output: 5
bind_output: 6
# The switch is used to control the D1~D6 level output on the KC868 HA board
# Other parameters refer to: https://esphome.io/components/switch/index.html
bind_output: 1
bind_output: 2
bind_output: 3
bind_output: 4
bind_output: 5
bind_output: 6
web_server:
port: 80
HAv2-F24-yaml.txt (Size: 3.04 KB / Downloads: 384)
Threads: 1,560
this yaml file include F24 all functions and HAv2.
Code: esphome:
friendly_name: f24
platformio_options:
board_build.extra_flags:
# WIFI_CONTROL_SELF_MODE = 0
# WIFI_CONTROL_SELF_MODE = 1
type: arduino
- source:
type: git
ref: v1.1.0
- source:
type: git
ref: v3.0.2
encryption:
type: W5500
clk_pin: GPIO42
mosi_pin: GPIO43
miso_pin: GPIO44
cs_pin: GPIO41
reset_pin: GPIO1
- id: bus_a
sda: 8
scl: 18
frequency: 400kHz
- id: 'pcf8574_hub_out_1' # for output channel 9-24
i2c_id: bus_a
address: 0x25
pcf8575: true
- id: 'pcf8574_hub_in_1' # for digital input channel 1-16
i2c_id: bus_a
address: 0x24
pcf8575: true
- id: 'pcf8574_hub_out_in_2' # for output channel 1-8 + (input 17-24)
i2c_id: bus_a
address: 0x26
pcf8575: true
uart:
- id: myuart1
tx_pin: 16
rx_pin: 17
baud_rate: 9600
debug:
direction: BOTH
- id: tuya_mcu_uart
tx_pin: GPIO39
rx_pin: GPIO38
baud_rate: 9600
tuya_wifi_mcu:
# tuya mcu product id
product_id: cchos3g1j2ucfbyd
uart_id: tuya_mcu_uart
wifi_reset_pin: 28
wifi_led_pin: 16
kc868_ha:
uart_id: myuart1
pcf8574: pcf8574_hub_out_in_2
number: 12
mode: OUTPUT
- platform: tuya_wifi_mcu
dp_id: 1
# hide from homeassistant ui
internal: true
bind_switch_id: "f24_output01"
number: 13
mode: OUTPUT
dp_id: 2
internal: true
bind_switch_id: "f24_output02"
number: 14
mode: OUTPUT
dp_id: 3
internal: true
bind_switch_id: "f24_output03"
number: 15
mode: OUTPUT
dp_id: 4
internal: true
bind_switch_id: "f24_output04"
number: 8
mode: OUTPUT
dp_id: 5
internal: true
bind_switch_id: "f24_output05"
number: 9
mode: OUTPUT
dp_id: 6
internal: true
bind_switch_id: "f24_output06"
number: 10
mode: OUTPUT
dp_id: 101
internal: true
bind_switch_id: "f24_output07"
number: 11
mode: OUTPUT
dp_id: 102
internal: true
bind_switch_id: "f24_output08"
pcf8574: pcf8574_hub_out_1
mode: OUTPUT
dp_id: 103
internal: true
bind_switch_id: "f24_output09"
mode: OUTPUT
dp_id: 104
internal: true
bind_switch_id: "f24_output10"
mode: OUTPUT
dp_id: 105
internal: true
bind_switch_id: "f24_output11"
mode: OUTPUT
dp_id: 106
internal: true
bind_switch_id: "f24_output12"
number: 4
mode: OUTPUT
dp_id: 107
internal: true
bind_switch_id: "f24_output13"
number: 5
mode: OUTPUT
dp_id: 108
internal: true
bind_switch_id: "f24_output14"
number: 6
mode: OUTPUT
dp_id: 109
internal: true
bind_switch_id: "f24_output15"
number: 7
mode: OUTPUT
dp_id: 110
internal: true
bind_switch_id: "f24_output16"
number: 8
mode: OUTPUT
dp_id: 126
internal: true
bind_switch_id: "f24_output17"
number: 9
mode: OUTPUT
dp_id: 129
internal: true
bind_switch_id: "f24_output18"
number: 10
mode: OUTPUT
dp_id: 130
internal: true
bind_switch_id: "f24_output19"
number: 11
mode: OUTPUT
dp_id: 131
internal: true
bind_switch_id: "f24_output20"
number: 12
mode: OUTPUT
dp_id: 132
internal: true
bind_switch_id: "f24_output21"
number: 13
mode: OUTPUT
dp_id: 133
internal: true
bind_switch_id: "f24_output22"
number: 14
mode: OUTPUT
dp_id: 134
internal: true
bind_switch_id: "f24_output23"
number: 15
mode: OUTPUT
dp_id: 135
internal: true
bind_switch_id: "f24_output24"
bind_output: 1
bind_output: 2
bind_output: 3
bind_output: 4
bind_output: 5
bind_output: 6
pcf8574: pcf8574_hub_in_1
dp_id: 111
bind_binary_sensor_id: f24_input01
internal: true
dp_id: 112
bind_binary_sensor_id: f24_input02
internal: true
dp_id: 113
bind_binary_sensor_id: f24_input03
internal: true
dp_id: 114
bind_binary_sensor_id: f24_input04
internal: true
number: 4
dp_id: 115
bind_binary_sensor_id: f24_input05
internal: true
number: 5
dp_id: 116
bind_binary_sensor_id: f24_input06
internal: true
number: 6
dp_id: 117
bind_binary_sensor_id: f24_input07
internal: true
number: 7
dp_id: 118
bind_binary_sensor_id: f24_input08
internal: true
number: 8
dp_id: 119
bind_binary_sensor_id: f24_input09
internal: true
number: 9
dp_id: 120
bind_binary_sensor_id: f24_input10
internal: true
number: 10
dp_id: 121
bind_binary_sensor_id: f24_input11
internal: true
number: 11
dp_id: 122
bind_binary_sensor_id: f24_input12
internal: true
number: 12
dp_id: 123
bind_binary_sensor_id: f24_input13
internal: true
number: 13
dp_id: 124
bind_binary_sensor_id: f24_input14
internal: true
number: 14
dp_id: 125
bind_binary_sensor_id: f24_input15
internal: true
number: 15
number: 4
number: 5
number: 6
number: 7
##pull-up resistance on PCB
number: 48
number: 47
number: 21
number: 15
## without resistance on PCB
number: 13
inverted: false
number: 14
inverted: false
number: 40
inverted: false
bind_output: 2
bind_output: 3
bind_output: 4
bind_output: 5
bind_output: 6
- platform: adc
pin: 5
name: "f24 A1 Voltage"
update_interval: 5s
attenuation: 11db
filters:
- lambda:
if (x >= 3.11) {
return x * 1.60256;
} else if (x <= 0.15) {
return 0;
} else {
return x * 1.51;
- platform: adc
pin: 7
name: "f24 A2 Voltage"
update_interval: 5s
attenuation: 11db
filters:
# - multiply: 1.51515
- lambda:
if (x >= 3.11) {
return x * 1.60256;
return 0;
} else {
return x * 1.51;
- platform: adc
pin: 6
name: "f24 A3 Current"
update_interval: 5s
unit_of_measurement: mA
attenuation: 11db
filters:
- multiply: 6.66666666
- platform: adc
pin: 4
name: "f24 A4 Current"
update_interval: 5s
attenuation: 11db
filters:
web_server:
port: 80
font:
- file: "gfonts://Roboto"
display:
- platform: ssd1306_i2c
i2c_id: bus_a
model: "SSD1306 128x64"
address: 0x3C
lambda: |-
it.printf(0, 0, id(roboto), "KinCony F24");
download yaml:
HAv2-F24-Tuya.txt (Size: 20.91 KB / Downloads: 345)
Threads: 1
I have F24 and HAv2 boards, is there a way to light up status LED (24V) of light switch when relay is open (240V) on F24, that doesn't rely on software?
I think most robust is something like this in ESPhome config but for regimentation I would prefer a non-software depending solution.
Thank you
Code: - platform: gpio
number: 12
mode: OUTPUT
on_turn_on:
- switch.turn_on: led_d6
on_turn_off:
- switch.turn_off: led_d6
Threads: 1,560
our wall switch LED work by DC12v. you can convert 24v->12v. when switch LED=0v, then LED ON, when switch LED=12v, LED OFF.
here is switch panel link: https://shop.kincony.com/products/moment...ush-button
Threads: 1
(01-08-2026, 12:19 AM)admin Wrote: our wall switch LED work by DC12v. you can convert 24v->12v. when switch LED=0v, then LED ON, when switch LED=12v, LED OFF.
I already have a light switch with 24V status LED.
What I mean is:
For my local regulation, it is not allowed that the relay provides 240V AC to light and that the light LED status is off.
Let's say i program a script in home assistant that turns status LED on/off, and home assistant is not working, then the status LED is possible not accurate (off when light is on, or on when light is off). This is not allowed.
With the code I gave (that I still need to test), I made sure that the LED status logic remains local on F24 board. So even if HA is down, the led status still works.
I think this is the most robust way to program it?
The best would be a hardware solution, maybe something for a future board? Where there is a board with double relay for one switch. One for 240V AC and one for 24/12V DC for status LED. On local switch push, or button press via HA both relays enable via hardware. Not via software.
Threads: 3
I have bought the F24, multiple HAv2, and multiple six contact switches same as shown in the photo above.
is there a way to implement the following:
single tap - achieved
double tap ?
long press
certain buttons define modes that allow the others to change their function, and led lights to turn on to signify the mode your in,
my wish is to use the same switch for :
lighting
blinds
music (basic controls)
controller is homeassistant where lighting , blinds and music have control endpoints.
Threads: 1,560
(01-08-2026, 08:00 AM)Painy Wrote: (01-08-2026, 12:19 AM)admin Wrote: our wall switch LED work by DC12v. you can convert 24v->12v. when switch LED=0v, then LED ON, when switch LED=12v, LED OFF.
What I mean is:
you can connect a DC24V small power supply to your relay output AC220V terminal.
Threads: 1,560
(01-08-2026, 10:57 PM)swisstmack25 Wrote: I have bought the F24, multiple HAv2, and multiple six contact switches same as shown in the photo above.
double tap ?
long press
lighting
blinds
HAv2 only support "single click" way. if you want "1-click", "2-click", "hold on" different actions. you can connect with controller's digital input ports directly, that supportted.
Threads: 1
01-11-2026, 09:14 AM
(This post was last modified: 01-11-2026, 09:15 AM by Painy.)
(01-09-2026, 01:03 AM)admin Wrote: (01-08-2026, 10:57 PM)swisstmack25 Wrote: I have bought the F24, multiple HAv2, and multiple six contact switches same as shown in the photo above.
double tap ?
long press
lighting
blinds
controller is homeassistant where lighting , blinds and music have control endpoints. HAv2 only support "single click" way. if you want "1-click", "2-click", "hold on" different actions. you can connect with controller's digital input ports directly, that supportted. Can't you program that in ESP home or automate it in HA?
Threads: 1,560
HAv2 use by ARM CPU, not ESP32, so can't use by ESPHome.
