A8 brick
Sad
Hi, unfortunately the flashing of the Kincony A8 failed. I flashed a compiled esphome bin file. It stopped always after a few percent. I tried multiple cables and an different baud rates. No success and now it is not responding anymore / seems bricked. I was working from a linux device:
.pdf   flash.pdf (Size: 74.75 KB / Downloads: 24)
It is the first time ever I had such an issue with an esp device. And I use them a lot - with WLED, custom procects etc. Is there maybe something wrong with the pcb design?
I hoped by buying a more expensive relais board to get not into trouble.
maybe need replace esp32 module. if you want use A8, suggest order A8v3 new version, it use by ESP32S3, it's better.
Wink
I just tried again to upload the bin file via your upload tool from windows. For whatever reason it worked. Puh.
ok, good.
