N60 N30 N20 N10 firmware BL0910 energy chip register RAW data structure
03-23-2026, 10:51 AM
>= ARM CPU firmware V20_260305SP data strcut changed, because of energy value support 0.001kwh. the new data struct is :
Energy variable update to "float" from "unit32". new is: Code: ///modbus data struct
If you read the entire data structure via Modbus (function code 0x03), you need to read 68 consecutive holding registers.
N10: you can read register address 100 just read 1pc of BL0910 chip N20: you can read register address 100 and 200 just read 2pcs of BL0910 chips N30: you can read register address 100 and 200 and 300 just read 3pcs of BL0910 chips N60: you can read register address 100 and 200 and 300 and 400 and 500 and 600 just read 6pcs of BL0910 chips
