05-01-2026, 12:47 AM
Hi, I have just received my N10 and its all working - except the kwh is always zero in homeassistant and on the "monitor" page on kc3
I have tried the ESPhome firmware and the KC3 firmware > MQTT > Homeassistant with the same results - screenshots below for reference
When i used the ESPhome firmware i used this config file which mentions fixing the kwh https://www.kincony.com/forum/attachment.php?aid=9373
I found this post - https://www.kincony.com/forum/showthread.php?tid=9107, and tried flashing via USBC port but it will not work - must this use the RS485?
Thank you
Thank you
