[arduino code examples for B2]-02 Read digital input ports state
   Made by KinCony IoT
   https://www.kincony.com
   Demo: KinCony B2 Digital Input Read
   Board: KinCony B2 (ESP32)
   Digital Input 1 -> GPIO6
   Digital Input 2 -> GPIO7
#define DI1_PIN 6
#define DI2_PIN 7
// Store previous input states
int lastDI1State = HIGH;
int lastDI2State = HIGH;
void setup()
  // Initialize serial monitor
  Serial.println("KinCony B2 Digital Input Demo");
  // Configure digital input pins
  // Change INPUT to INPUT_PULLUP if your hardware requires internal pull-up
  pinMode(DI1_PIN, INPUT_PULLUP);
  pinMode(DI2_PIN, INPUT_PULLUP);
  // Read initial states
  lastDI1State = digitalRead(DI1_PIN);
  lastDI2State = digitalRead(DI2_PIN);
  Serial.print("DI1 Initial State: ");
  Serial.println(lastDI1State);
  Serial.print("DI2 Initial State: ");
  Serial.println(lastDI2State);
void loop()
  // Read current input states
  int di1State = digitalRead(DI1_PIN);
  int di2State = digitalRead(DI2_PIN);
  // Check if DI1 state changed
  if (di1State != lastDI1State)
    lastDI1State = di1State;
    Serial.print("DI1 Changed: ");
    Serial.println(di1State);
  // Check if DI2 state changed
  if (di2State != lastDI2State)
    lastDI2State = di2State;
    Serial.print("DI2 Changed: ");
    Serial.println(di2State);
  // Small delay for stability
  delay(10);
arduino ino file download:
.zip   2-digital-input.zip (Size: 697 bytes / Downloads: 12)
.zip   2-digital-input.ino.merged.zip (Size: 180.26 KB / Downloads: 14)
