KC868-A16 error in HASS yaml
The yaml file for de kc868-a16 is giving errors i a will validate this in homeassistant.
https://www.kincony.com/kc868-a16-ethern...igure.html
Reading configuration /config/esphome/IO_Bord_001.yaml...
ERROR Error while reading config: Invalid YAML syntax:
Duplicate key "– id"
  in "/config/esphome/IO_Bord_001.yaml", line 32, column 1:
    – id: ‘pcf8574_hub_in_1’ # for i ...
NOTE: Previous declaration here:
  in "/config/esphome/IO_Bord_001.yaml", line 29, column 1:
    – id: ‘pcf8574_hub_out_1’ # for  ...
Is there a newer version?
Do you copy this config text in your ESPHome?
[Image: KC868-A16_ESPHome.png]
No, its not working.
I want change the default IP from 192.168.1.199 to 192.168.200.100. I have change that in the file as on your site, but the ESPHomne give a error so that i cant flash te board.
Because the standard IP adress is not in my range from HA i can't communicate.
check your space number behind - , because the webpage format problem.
(02-27-2022, 11:47 PM)admin Wrote: check your space number behind -  , because the webpage format problem.
Ik don't see it  Huh
Please can you send the file to: email.avs412@gmail.com ?
ok, later we send you a txt format file.
it's format problem by webpage. look at the color of - and '
you can download this config txt file, unzip it , copy text to your ESPHome config file directly.
.zip   Made_for_ESPHome_KC868-A16.zip (Size: 882 bytes / Downloads: 1,054)
send to your email, but failure, you just download the zip file will be ok.
Working great.
Thanks for your support!
Thankyou Admin
I was having the same issue, now working :-)
Pete
