Loxone XML template file for KC868-H32B
You just need to select "Virtual Outputs" and import this template. After this file is imported only the IP address as per user's ip address has to be give. There is no need to configure all the 32 relays for ON and OFF commands.
.zip   VO_KC868-H32B.zip (Size: 710 bytes / Downloads: 938)
