improvement:
mainly support integrate to Loxone Mini-Server by RS232 port.
1. after INPUT trigger (when released input with GND) will auto feedback "DIARM" message to TCP client and RS232.
such as if you let INPUT short with GND, will send "RELAY-ALARM-1,OK" , that means: INPUT-1 is trigger.
when released, will send "RELAY-DIARM-1,OK" , that means: INPUT-1 is released, just "disable alarm".
2. It supports sending multiple control relay commands to the KC868-H32B at one time by RS232 or TCP. The controller will process them in a queue without discarding the commands. At most, MAX 32 commands can be received at the same time
such as you can send these command at one time by RS232 or TCP:
RELAY-SET-255,1,1
RELAY-SET-255,2,1
RELAY-SET-255,3,1
RELAY-SET-255,4,1
RELAY-SET-255,5,1
RELAY-SET-255,6,1
RELAY-SET-255,7,1
RELAY-SET-255,8,1
RELAY-SET-255,9,1
RELAY-SET-255,10,1
RELAY-SET-255,11,1
RELAY-SET-255,12,1
RELAY-SET-255,13,1
RELAY-SET-255,14,1
RELAY-SET-255,15,1
RELAY-SET-255,16,1
RELAY-SET-255,17,1
RELAY-SET-255,18,1
RELAY-SET-255,19,1
RELAY-SET-255,20,1
RELAY-SET-255,21,1
RELAY-SET-255,22,1
RELAY-SET-255,23,1
RELAY-SET-255,24,1
RELAY-SET-255,25,1
RELAY-SET-255,26,1
RELAY-SET-255,27,1
RELAY-SET-255,28,1
RELAY-SET-255,29,1
RELAY-SET-255,30,1
RELAY-SET-255,31,1
RELAY-SET-255,32,1
Relay32_V443_220402.zip (Size: 47.02 KB / Downloads: 1,063)
download the ZIP file , unzip update the bin file for KC868-H32B relay controller by USB-RS232 cable.
RELAY-SET-255,1,1
RELAY-SET-255,2,1
RELAY-SET-255,3,1
RELAY-SET-255,4,1
RELAY-SET-255,5,1
RELAY-SET-255,6,1
RELAY-SET-255,7,1
RELAY-SET-255,8,1
RELAY-SET-255,9,1
RELAY-SET-255,10,1
RELAY-SET-255,11,1
RELAY-SET-255,12,1
RELAY-SET-255,13,1
RELAY-SET-255,14,1
RELAY-SET-255,15,1
RELAY-SET-255,16,1
RELAY-SET-255,17,1
RELAY-SET-255,18,1
RELAY-SET-255,19,1
RELAY-SET-255,20,1
RELAY-SET-255,21,1
RELAY-SET-255,22,1
RELAY-SET-255,23,1
RELAY-SET-255,24,1
RELAY-SET-255,25,1
RELAY-SET-255,26,1
RELAY-SET-255,27,1
RELAY-SET-255,28,1
RELAY-SET-255,29,1
RELAY-SET-255,30,1
RELAY-SET-255,31,1
RELAY-SET-255,32,1
