[Arduino demo source code for KC868-A4]-13 work with KBOX phone app
use for "KBOX" phone app in local network , without internet.
.zip   KBOX.zip (Size: 837 bytes / Downloads: 1,021)
Sad
(05-04-2022, 11:40 AM)admin Wrote: use for "KBOX" phone app in local network , without internet.
hello admin.
I have a KC868-A8, I am trying to use KBOX to control the Relays, but running the application does not activate the relays, can you help me with this?
Thanks for everything.
this is the code:
#include <WiFi.h>
#include "Arduino.h"
#include "PCF8574.h"
const char* ssid = "ARRIS-1001";
const char* password =  "AAAAABBBBBCCCCC";
//Salidas -OUTPUTS
PCF8574 pcf8574_S(0x24);
//Entradas -INPUTS
PCF8574 pcf8574(0x22);
WiFiServer wifiServer(4196);
// Set pinMode to OUTPUT
  pcf8574_S.pinMode(P0, OUTPUT);
  pcf8574_S.pinMode(P1, OUTPUT);
  pcf8574_S.pinMode(P2, OUTPUT);
  pcf8574_S.pinMode(P3, OUTPUT);
  pcf8574_S.pinMode(P4, OUTPUT);
  pcf8574_S.pinMode(P5, OUTPUT);
  pcf8574_S.pinMode(P6, OUTPUT);
  pcf8574_S.pinMode(P7, OUTPUT);
//Entradas -  to INPUTS
pcf8574.pinMode(P0, INPUT);
pcf8574.pinMode(P1, INPUT);
pcf8574.pinMode(P2, INPUT);
pcf8574.pinMode(P3, INPUT);
pcf8574.pinMode(P4, INPUT);
pcf8574.pinMode(P5, INPUT);
pcf8574.pinMode(P6, INPUT);
pcf8574.pinMode(P7, INPUT);
  delay(1000);
  WiFi.begin(ssid, password);
    delay(1000);
    Serial.println("Connecting to WiFi..");
  Serial.println("Connected to the WiFi network");
  wifiServer.begin();
  WiFiClient client = wifiServer.available();
  if (client) {
    while (client.connected()) {
      while (client.available()>0) {
      Serial.print("incoming :");
      int size;
      while ((size = client.available()) > 0) {
        uint8_t* msg = (uint8_t*)malloc(size);
        size = client.read(msg, size);
        Serial.write(msg, size);
        if ( memcmp(msg, "RELAY-SET-255,1,1", 17) == 0 ) {Serial.write("RELAY-SET-255,1,1,OK");pcf8574_S.digitalWrite(P0,HIGH);client.write("RELAY-SET-255,1,1,OK");}
        if ( memcmp(msg, "RELAY-SET-255,1,0", 17) == 0 ) {Serial.write("RELAY-SET-255,1,0,OK");pcf8574_S.digitalWrite(P0,LOW);client.write("RELAY-SET-255,1,0,OK");}
        if ( memcmp(msg, "RELAY-SET-255,2,1", 17) == 0 ) {Serial.write("RELAY-SET-255,2,1,OK");pcf8574_S.digitalWrite(P1,HIGH);client.write("RELAY-SET-255,2,1,OK");}
        if ( memcmp(msg, "RELAY-SET-255,2,0", 17) == 0 ) {Serial.write("RELAY-SET-255,2,0,OK");pcf8574_S.digitalWrite(P1,LOW);client.write("RELAY-SET-255,2,0,OK");}
        if ( memcmp(msg, "RELAY-SET-255,3,1", 17) == 0 ) {Serial.write("RELAY-SET-255,3,1,OK");pcf8574_S.digitalWrite(P2,HIGH);client.write("RELAY-SET-255,3,1,OK");}
        if ( memcmp(msg, "RELAY-SET-255,3,0", 17) == 0 ) {Serial.write("RELAY-SET-255,3,0,OK");pcf8574_S.digitalWrite(P2,LOW);client.write("RELAY-SET-255,3,0,OK");}
        if ( memcmp(msg, "RELAY-SET-255,4,1", 17) == 0 ) {Serial.write("RELAY-SET-255,4,1,OK");pcf8574_S.digitalWrite(P3,HIGH);client.write("RELAY-SET-255,4,1,OK");}
        if ( memcmp(msg, "RELAY-SET-255,4,0", 17) == 0 ) {Serial.write("RELAY-SET-255,4,0,OK");pcf8574_S.digitalWrite(P3,LOW);client.write("RELAY-SET-255,4,0,OK");}
        if ( memcmp(msg, "RELAY-SET-255,5,1", 17) == 0 ) {Serial.write("RELAY-SET-255,5,1,OK");pcf8574_S.digitalWrite(P4,HIGH);client.write("RELAY-SET-255,5,1,OK");}
        if ( memcmp(msg, "RELAY-SET-255,5,0", 17) == 0 ) {Serial.write("RELAY-SET-255,5,0,OK");pcf8574_S.digitalWrite(P4,LOW);client.write("RELAY-SET-255,5,0,OK");}
        if ( memcmp(msg, "RELAY-SET-255,6,1", 17) == 0 ) {Serial.write("RELAY-SET-255,6,1,OK");pcf8574_S.digitalWrite(P5,HIGH);client.write("RELAY-SET-255,6,1,OK");}
        if ( memcmp(msg, "RELAY-SET-255,6,0", 17) == 0 ) {Serial.write("RELAY-SET-255,6,0,OK");pcf8574_S.digitalWrite(P5,LOW);client.write("RELAY-SET-255,6,0,OK");}
        if ( memcmp(msg, "RELAY-SET-255,7,1", 17) == 0 ) {Serial.write("RELAY-SET-255,7,1,OK");pcf8574_S.digitalWrite(P6,HIGH);client.write("RELAY-SET-255,7,1,OK");}
        if ( memcmp(msg, "RELAY-SET-255,7,0", 17) == 0 ) {Serial.write("RELAY-SET-255,7,0,OK");pcf8574_S.digitalWrite(P6,LOW);client.write("RELAY-SET-255,7,0,OK");}
        if ( memcmp(msg, "RELAY-SET-255,8,1", 17) == 0 ) {Serial.write("RELAY-SET-255,8,1,OK");pcf8574_S.digitalWrite(P7,HIGH);client.write("RELAY-SET-255,8,1,OK");}
        if ( memcmp(msg, "RELAY-SET-255,8,0", 17) == 0 ) {Serial.write("RELAY-SET-255,8,0,OK");pcf8574_S.digitalWrite(P7,LOW);client.write("RELAY-SET-255,8,0,OK");}
        free(msg);
  //    client.write(c);
    // delay(10);
    client.stop();
do you have set the correct I2C address in your arduino IDE config file?
I think so,
I'm using for outputs.
(05-07-2022, 02:56 AM)Hector_Lozano Wrote: I think so,
These two lines of code are modified into the following:
//Salidas -OUTPUTS
PCF8574 pcf8574_S(0x24,4,5);
//Entradas -INPUTS
PCF8574 pcf8574(0x22,4,5);
That's right, I modified
you should set the A8 to MQTT mode    i think now your code is use TCP mode
