Threads: 11
NODE-RED sees the /dev/ttyS0 and even connects to it, but every command send fail.
I changed Ubuntu Core to Raspberry Pi OS Lite and still same issue.
I have another KC868-Server, so I will try if there is the same problem.
Threads: 1,559
ok, you can try to use another.
Threads: 1,559
if you have USB-RS485 adapter. you can let KC868-Server's RS485 connect to your USB-RS485, let your USB-RS485 connect with a PC, use "serial debug tool" to see whether have received message from KC868-Server.
