  • 2 Vote(s) - 5 Average
Configure KC868-A8 in ESPHome
¿How can I configured/flash my KC868-A8 in ESPHome (Home Assistant) for this sensors?
*Two Digital Inputs S3 and 54,
*Two Analog Inputs A1 and A2
*Two Temperature sensors Input S1and S2 can connect
DS18B20 Temperature sensor or DHT11 or DHT21 temperature and Humdity Sensor.
Does anyone have a complete KC868-A8 .yaml file to configure ESPHome?
Thankyou in advance
actually every parts we already have some different config file by different video tour.
if you want all in one config file, we can make it for you.
(07-06-2022, 01:17 PM)admin Wrote: actually every parts we already have some different config file by different video tour.
really the only thing I want is to incorporate the pending sensors into the home assistant:
Digital inputs S4 and S5
Analog inputs A1 and A2
Temperature sensors S1 and S2
Two
ok, when we have free time, make a config file for you, maybe need 2-3 days.
(07-06-2022, 02:47 PM)admin Wrote: ok, when we have free time, make a config file for you, maybe need 2-3 days.
Thank you in advance!
you can use this config file:
.txt   A8-esphome.txt (Size: 3.35 KB / Downloads: 782)
ds18b20 used pin14 in config file.
actually you can use 4 channel ports all use for DS18B20, just change GPIO number:
DS18B20/DHT11/DHT21/LED strip -1: 14
DS18B20/DHT11/DHT21/LED strip -2: 13
DS18B20/DHT11/DHT21/LED strip -2: 32
S3 and S4 is config by digital input.
(07-07-2022, 06:06 AM)admin Wrote: you can use this config file:
Thank you very much!
According to what the KC868 schematic indicates for the temperature, it would be pins 13, 14, 36 and 39?
I don't have any experiencie so... I am not sure!
.pdf   KC868-A8-schematic.pdf (Size: 940.97 KB / Downloads: 519)
you can see this the newest version : V1.4  https://www.kincony.com/download/KC868-A8-PCBV1.4.pdf
I need to update the firmware?
not need, just different hardware version, you can see your A8 board PCB whether printed V1.4
