[Arduino IDE demo source code for KC868-A4]--#12-WEB_SERVER_CODE
KC868-A4_Web_Server.zip (Size: 454.76 KB / Downloads: 722)
* Create Your own WebServer for KC868-A4 Smart Controller*
* https://www.kincony.com **
// Load Wi-Fi library
#include <WiFi.h>
#include <WiFiManager.h>
#define TRIGGER_PIN 0 // reset wifi button
WiFiManager wm;
/* const char* ssid = "xxx"; //your router's ssid
WiFiServer server(80);
String header;
// Current time
// Previous time
int flag_read_di=0;
pinMode(2,OUTPUT);
pinMode(15,OUTPUT);
pinMode(5,OUTPUT);
pinMode(4,OUTPUT);
pinMode(36,INPUT);
pinMode(39,INPUT);
pinMode(27,INPUT);
pinMode(14,INPUT);
digitalWrite(2, HIGH);
digitalWrite(15,HIGH);
digitalWrite(5, HIGH);
digitalWrite(4, HIGH);
WiFi.mode(WIFI_STA);
bool res;
res = wm.autoConnect("KC868-A4-AP"); // anonymous ap
if(!res) {
else {
Serial.println("");
server.begin();
void loop(){
currentTime = millis();
previousTime = currentTime;
header += c;
client.println();
// turns 16 relays on and off
if (header.indexOf("GET /1/on") >= 0) {relay1state = "on"; digitalWrite(2, HIGH);}
else if (header.indexOf("GET /1/off") >= 0) {relay1state = "off";digitalWrite(2, LOW);}
else if (header.indexOf("GET /2/on") >= 0) {relay2state = "on"; digitalWrite(15, HIGH);}
else if (header.indexOf("GET /2/off") >= 0) {relay2state = "off";digitalWrite(15, LOW);}
else if (header.indexOf("GET /3/on") >= 0) {relay3state = "on"; digitalWrite(5, HIGH);}
else if (header.indexOf("GET /3/off") >= 0) {relay3state = "off";digitalWrite(5, LOW);}
else if (header.indexOf("GET /4/on") >= 0) {relay4state = "on"; digitalWrite(4, HIGH);}
else if (header.indexOf("GET /4/off") >= 0) {relay4state = "off";digitalWrite(4, LOW);}
digitalWrite(15,LOW);
// Display the HTML web page
if (flag_read_di==1)
client.println(" relay1:" + relay1state + " relay2:" + relay2state + " relay3:" + relay3state + " relay4:" + relay4state );
else
// Web Page Heading
client.println("<body><h1>KC868-A4 Web Server</h1>");
client.println();
break;
currentLine = "";
// Clear the header variable
header = "";
// Close the connection
client.stop();
Serial.println("");
flag_read_di=0;
ScanKey(); //scan key
void ScanKey()
if(digitalRead(36) == LOW) //key pressed
delay(20);
if(digitalRead(36) == LOW) //key pressed again
digitalWrite(2,!digitalRead(2)); // toggle relay1 state
while(digitalRead(36) == LOW); //wait remove hand
if (digitalRead(2) == LOW) relay1state="on";else relay1state="off";
if(digitalRead(39) == LOW) //key pressed
delay(20);
if(digitalRead(39) == LOW) //key pressed again
digitalWrite(15,!digitalRead(15)); // toggle relay1 state
while(digitalRead(39) == LOW); //wait remove hand
if (digitalRead(15) == LOW) relay2state="on";else relay2state="off";
if(digitalRead(27) == LOW) //key pressed
delay(20);
if(digitalRead(27) == LOW) //key pressed again
digitalWrite(5,!digitalRead(5)); // toggle relay1 state
while(digitalRead(27) == LOW); //wait remove hand
if (digitalRead(5) == LOW) relay3state="on";else relay3state="off";
if(digitalRead(14) == LOW) //key pressed
delay(20);
if(digitalRead(14) == LOW) //key pressed again
digitalWrite(4,!digitalRead(4)); // toggle relay1 state
while(digitalRead(14) == LOW); //wait remove hand
if (digitalRead(4) == LOW) relay4state="on";else relay4state="off";
