[Arduino IDE demo source code for KC868-A8S]--#15-KC868-A8S_Web_server_code
.zip   KC868-A8S_Web_Server.zip (Size: 462.39 KB / Downloads: 668)
* Create Your own WebServer for KC868-A8S Smart Controller*
// Load Wi-Fi library
#include <WiFi.h>
#include "PCF8574.h"
#include <WiFiManager.h>
#define TRIGGER_PIN 0   // reset wifi button
WiFiManager wm;
/* const char* ssid     = "xxx"; //your router's ssid
WiFiServer server(80);
String header;
// Current time
// Previous time
int flag_read_di=0;
TwoWire I2Cone = TwoWire(0);
TwoWire I2Ctwo = TwoWire(1);
//set I2C of A8S
PCF8574 pcf8574_I1(&I2Cone,0x22,4,5);
PCF8574 pcf8574_R1(&I2Cone,0x24,4,5);
String relaystate[16]={"relay1state","relay2state","relay3state","relay4state",
                       "relay5state","relay6state","relay7state","relay8state",
  for(int i=0;i<=7;i++)
  pcf8574_R1.begin();
     pcf8574_I1.pinMode(i, INPUT);
    pcf8574_I1.begin();
    WiFi.mode(WIFI_STA);
     bool res;
       res = wm.autoConnect("KC868-A8S-AP"); // anonymous ap
    if(!res) {
    else {
  Serial.println("");
  server.begin();
void loop(){
  WiFiClient client = server.available();   // Listen for incoming clients
    currentTime = millis();
    previousTime = currentTime;
        header += c;
            client.println();
            // turns 16 relays on and off
            // Display the HTML web page
            if (flag_read_di==1)
              client.println(" relay1:" + relay1state + " relay2:" + relay2state + " relay3:" + relay3state + " relay4:" + relay4state + " relay5:" + relay5state + " relay6:" + relay6state + " relay7:" + relay7state + " relay8:" + relay8state);
            else
            // Web Page Heading
            client.println("<body><h1>KC868-A8S Web Server</h1>");
            client.println();
            break;
            currentLine = "";
    // Clear the header variable
    header = "";
    // Close the connection
    client.stop();
    Serial.println("");
    flag_read_di=0;
void ScanKey()
    if(pcf8574_I1.digitalRead(i) == LOW)         //key pressed
        delay(20);
        if(pcf8574_I1.digitalRead(i) == LOW)       //key pressed again
