Specific libraries to compile the KC868-A32 Demo
Could you specify the exact libraries to compile the demo for:
PCF8574.h  (there are many available to install)
WiFiManager.h
Sorry if this is an obvious answer to experienced users, I get numerous errors and I've tried many libraries
WARNING: library WiFiManager-master claims to run on esp8266, esp32 architecture(s) and may be incompatible with your current board which runs on avr architecture(s).
KC868-A32_Web_Server:11:1: error: 'WiFiManager' does not name a type; did you mean 'WiFiManager_h'?
WiFiManager wm;
WiFiManager_h
KC868-A32_Web_Server:34:27: error: no matching function for call to 'TwoWire::TwoWire(int)'
TwoWire I2Cone = TwoWire(0);
In file included from C:\Users\spvis\Documents\Arduino\libraries\PCF8574_library/PCF8574.h:38:0,
                from C:\Users\spvis\Documents\Arduino\KC868-A32\KC868-A32_Web_Server\KC868-A32_Web_Server.ino:8:
C:\Users\spvis\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src/Wire.h:52:5: note: candidate: TwoWire::TwoWire()
    TwoWire();
C:\Users\spvis\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src/Wire.h:52:5: note:  candidate expects 0 arguments, 1 provided
C:\Users\spvis\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src/Wire.h:34:7: note: candidate: constexpr TwoWire::TwoWire(const TwoWire&)
class TwoWire : public Stream
C:\Users\spvis\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src/Wire.h:34:7: note:  no known conversion for argument 1 from 'int' to 'const TwoWire&'
C:\Users\spvis\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src/Wire.h:34:7: note: candidate: constexpr TwoWire::TwoWire(TwoWire&&)
C:\Users\spvis\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src/Wire.h:34:7: note:  no known conversion for argument 1 from 'int' to 'TwoWire&&'
KC868-A32_Web_Server:35:27: error: no matching function for call to 'TwoWire::TwoWire(int)'
TwoWire I2Ctwo = TwoWire(1);
    TwoWire();
KC868-A32_Web_Server:37:41: error: no matching function for call to 'PCF8574:TongueCF8574(TwoWire*, int, int, int)'
PCF8574 pcf8574_R1(&I2Ctwo, 0x24, 15, 13);
In file included from C:\Users\spvis\Documents\Arduino\KC868-A32\KC868-A32_Web_Server\KC868-A32_Web_Server.ino:8:0:
C:\Users\spvis\Documents\Arduino\libraries\PCF8574_library/PCF8574.h:110:2: note: candidate: PCF8574:TongueCF8574(uint8_t, uint8_t, void (*)())
  PCF8574(uint8_t address, uint8_t interruptPin,  void (*interruptFunction)() );
C:\Users\spvis\Documents\Arduino\libraries\PCF8574_library/PCF8574.h:110:2: note:  candidate expects 3 arguments, 4 provided
C:\Users\spvis\Documents\Arduino\libraries\PCF8574_library/PCF8574.h:109:2: note: candidate: PCF8574:TongueCF8574(uint8_t)
  PCF8574(uint8_t address);
C:\Users\spvis\Documents\Arduino\libraries\PCF8574_library/PCF8574.h:109:2: note:  candidate expects 1 argument, 4 provided
C:\Users\spvis\Documents\Arduino\libraries\PCF8574_library/PCF8574.h:106:7: note: candidate: constexpr PCF8574:TongueCF8574(const PCF8574&)
class PCF8574 {
C:\Users\spvis\Documents\Arduino\libraries\PCF8574_library/PCF8574.h:106:7: note:  candidate expects 1 argument, 4 provided
C:\Users\spvis\Documents\Arduino\libraries\PCF8574_library/PCF8574.h:106:7: note: candidate: constexpr PCF8574:TongueCF8574(PCF8574&&)
KC868-A32_Web_Server:39:41: error: no matching function for call to 'PCF8574:TongueCF8574(TwoWire*, int, int, int)'
PCF8574 pcf8574_R3(&I2Ctwo, 0x21, 15, 13);
class PCF8574 {
KC868-A32_Web_Server:45:39: error: no matching function for call to 'PCF8574:TongueCF8574(TwoWire*, int, int, int)'
PCF8574 pcf8574_I3(&I2Cone, 0x21, 4, 5);
C:\Users\spvis\Documents\Arduino\KC868-A32\KC868-A32_Web_Server\KC868-A32_Web_Server.ino: In function 'void setup()':
KC868-A32_Web_Server:132:8: error: 'class WiFiClass' has no member named 'mode'
  WiFi.mode(WIFI_STA);
KC868-A32_Web_Server:132:13: error: 'WIFI_STA' was not declared in this scope
KC868-A32_Web_Server:134:5: error: 'wm' was not declared in this scope
C:\Users\spvis\Documents\Arduino\KC868-A32\KC868-A32_Web_Server\KC868-A32_Web_Server.ino: In function 'void loop()':
KC868-A32_Web_Server:449:42: error: 'wm' was not declared in this scope
KC868-A32_Web_Server:449:61: error: 'ESP' was not declared in this scope
C:\Users\spvis\Documents\Arduino\KC868-A32\KC868-A32_Web_Server\KC868-A32_Web_Server.ino:449:61: note: suggested alternative: 'SP'
                                                            SP
exit status 1
here are two library zip file , you can copy to your arduino library folder.
.zip   PCF8574_library.zip (Size: 23.8 MB / Downloads: 864)
.zip   WiFiManager.zip (Size: 139.57 KB / Downloads: 721)
(10-11-2022, 10:31 PM)admin Wrote: here are two library zip file , you can copy to your arduino library folder.
Thank you!
you are welcome.
(10-12-2022, 01:46 AM)admin Wrote: you are welcome.
Would you have any demos on how to wire up I2C devices?  I have 5 SHT30 Temperature/Humidity sensors I'd like to connect to the KC868-A32.  I've done this no problem on the Arduinio ESP32 dev board but I'm not sure of where to connect on the KC868 board and don;t want to fry anything.
There is a white IIC extender socket on the center of KC868-A32 board. you can connect with your SHT30 senosr's SDA , SCL and Vcc, GND with these 4 PINs, it's easy. then you should know your SHT30's IIC address use in your code.
(10-17-2022, 12:08 AM)admin Wrote: There is a white IIC extender socket on the center of KC868-A32 board. you can connect with your SHT30 senosr's SDA , SCL and Vcc, GND with these 4 PINs, it's easy. then you should know your SHT30's IIC address use in your code.
So I cannot use any of the GIO pins for I2C,  I connect all of the I2C sensors to the single 4 pin connector in the center of the board?
it's up to you. if you want to use exist IIC bus, just connect to " 4 pin connector in the center of the board"
if you want to use free GIPO for new IIC bus, you can use other GPIOs.
(10-17-2022, 10:25 AM)admin Wrote: it's up to you. if you want to use exist IIC bus, just connect to " 4 pin connector in the center of the board"
Could you help me identify which model/brand the white IIC extender socket  is on the A32 board? So I can buy the proper female connector to plug into it. Thank you.
any 2.54mm plugin can be used, easy to find in market.
