KC868-A6 tasmota
ola personal, someone has already cofollowed install the tasmota, I can install more does not open the field to configure the pulse input, someone has already managed
KC868-A6 use way of tasmota as same as KC868-A8's
(10-30-2022, 12:57 AM)admin Wrote: KC868-A6 maneira de uso de tasmota como kC868-A8
even following these steps does not appear the option of PCF8574 to activate
here is details: https://www.kincony.com/forum/showthread.php?tid=1128
just do as that step by step.
(10-30-2022, 10:30 PM)admin Wrote: here is details: https://www.kincony.com/forum/showthread.php?tid=1128
exactly, I have another board and it worked, in this not, I realized that whenever saved, changes the configuration, different from the tutorial , does not save the last settings
{"NAME":"KC868-A8","GPIO":[32,0,1120,0,640,608,0,0,0,1,1,1152,0,0,5600,0,0,0,0,5568,0,0,0,0,0,0,0,0,1,1,0,0,1,0,0,1],"FLAG":0,"BASE":1}
KC868-A6 need use tasmota by wifi, not by ethernet, maybe you have copy A8's setting? that have ethernet setting.
(11-01-2022, 04:53 AM)admin Wrote: KC868-A6 need use tasmota by wifi, not by ethernet, maybe you have copy A8's setting? that have ethernet setting.
I understand, how can I get the tasmota wifi firmware for the A6?would have some step by step
I think you can use this tasmota cloud compiler tool to generate firmware BIN file, it's very easy.
https://github.com/benzino77/tasmocompiler
you can try to use this firmware. unzip and download BIN file to ESP32.
.zip   tasmota4M.zip (Size: 482.19 KB / Downloads: 596)
(11-02-2022, 01:28 PM)admin Wrote: you can try to use this firmware. unzip and download BIN file to ESP32.
yes, I already tested what you posted on the forum, but it didn't work, I'll end up giving up, thanks for your attention
I tried this tutorial but without success
https://forum.cpha.pt/t/tasmota-esphome-...23017/5249
