"KCS" v1.0.24 firmware BIN file download
How to download and use, online guide: https://www.kincony.com/kcs-firmware-esp32-board.html
v1.0.24 improment:
1. Fix some text in webpage.
2. Fix timer bug for different channel reset problem.
3. Let MQTT message feedback only one time, before will be twice.
4. Support RS485 MODBUS Button Adapter – KC868-HA
5. Fix bug of DAC output with tuya app problem.
.zip   KCS_KC868_A4_V1.0.24.zip (Size: 737.3 KB / Downloads: 1,223)
.zip   KCS_KC868_A6_V1.0.24.zip (Size: 744.95 KB / Downloads: 1,044)
.zip   KCS_KC868_A8_V1.0.24.zip (Size: 748.43 KB / Downloads: 1,002)
.zip   KCS_KC868_A8S_V1.0.24.zip (Size: 755.91 KB / Downloads: 984)
.zip   KCS_KC868_A16_V1.0.24.zip (Size: 756.16 KB / Downloads: 1,037)
.zip   KCS_KC868_A32_V1.0.24.zip (Size: 756.24 KB / Downloads: 1,119)
.zip   KCS_KC868_A64_V1.0.24.zip (Size: 756.17 KB / Downloads: 992)
.zip   KCS_KC868_A128_V1.0.24.zip (Size: 756.25 KB / Downloads: 1,035)
.zip   KCS_KC868_AI_V1.0.24.zip (Size: 750.33 KB / Downloads: 1,219)
.zip   KCS_KC868_AK_V1.0.24.zip (Size: 738.35 KB / Downloads: 1,001)
.zip   KCS_KC868_E16S_V1.0.24.zip (Size: 756.17 KB / Downloads: 1,038)
.zip   KCS_KC868_A2_V1.0.25.zip (Size: 716.5 KB / Downloads: 996)
Hi
After update, all of my saved settings were gone. Is there a possibility to store the settings and reload after update?
sorry, because before update will erase the ESP32 chip.
I asked this question too. Because the kcs firmware uses a browser interface it should not be that difficult to save settings in a local file on computer to reload after firmware update.
we will save this suggestion.
Hi
I connected DS18b20 sensor to temp port where does the temperature show on the web page
KC868 A4 with KCS1.0.24
Thank you
now "KCS" not support show DS18B20, but in furture will update it.
Two questions about this version:
- Have you added support KC868_A16 for rs485 wall switch ?
- Have you added support KC868_A16 in the domoticz plug-in?
Bug Found:
- The TimeZone feature de not work properly
       We need to set TZ +8 to get the right time
Can you add support for specific use of MQTT with domoticz (need idx parameters in I/O config pages)?
now KCS support RS485 adapter -- KC868-HA, you can use by old switch panel.
you can integrate by MQTT. here is MQTT document:
https://www.kincony.com/forum/showthread.php?tid=2529
(04-17-2023, 12:24 AM)admin Wrote: now "KCS" not support show DS18B20, but in furture will update it.
Thank you for your reply
is this in the near future?
