Threads: 1,371
yes, in furture will add it.
Threads: 0
after flash my KCS_KC868- AK with KCS_KC868_AK_V1.0.24.zip, the KCS_KC868_AK has stopped communicating with the KC868-H32B-PRO via RS232 and RS485, now when I press the buttons on the KCS_KC868_AK, the relays are not activated on the KC868-H32B-PRO, how do I get it working again?
Threads: 1,371
you can download with E16S' , but after you download, your E16T tuya wifi module will not work.
Threads: 0
In manual says that OUTPUT delay time may be 1 - 255 x 100ms, but I need a 20 minutes delay. How can I implement this?
Threads: 1,371
if 20 minutes, go to "schedule" webpage, create "schedule" for it.
Threads: 0
I need to disable OUTPUT in 20min after disabling INPUT.
I tried schedule section, but I cant find any way to start time counting after disabling INPUT, or any other ways to use inputs as trigger for schedules.
Can you explain the solution with schedules?
Threads: 1,371
i am not understand your question, maybe you can draw a photo?
Threads: 0
For example:
If I single-click INPUT1, then OUTPUT1 turns on. After 20 minutes, OUTPUT1 should turn off automatically.
