07-24-2023, 03:01 AM
(This post was last modified: 08-22-2023, 05:59 AM by KinCony Support.)
Learn the remoter of E8T
07-25-2023, 08:35 AM
Good Day! I would like to use one RF button for turning ON and turning OFF all the relays of KC868-E8T. Same with the functionality in tuya where there is ALL ON and ALL OFF button.
Since the RF remote contain 16 Buttons. Hoping for your response
07-25-2023, 08:50 AM
do you want: remote button key1->relay1, key2->relay2, key3->relay3, key4->relay4, key5->relay5, key6->relay6, key7->relay7, key8->relay8,key9->8 relay ALL ON, key10->8 relay ALL OFF?
07-26-2023, 07:09 AM
07-26-2023, 10:27 AM
suggest use two different button. unless if your hold on the remoter's button, all relay will ON/OFF/ON/OFF loop.
08-03-2023, 01:10 PM
08-04-2023, 12:18 AM
it need modify arduino code, already sent you source code. you need to check by yourself.
08-09-2023, 08:13 AM
08-09-2023, 10:52 PM
which library? list at here.
08-13-2023, 06:51 AM
(08-09-2023, 10:52 PM)admin Wrote: which library? list at here. you have send me the source code for the 8 channel and found out that there are errors even though i include all the library that i will be needing. I just need to modify the RF side but having errors while verifying causing me time to modify the RF Side ., Kindly assist me on this matter |
