"KCS" v2.0.5 firmware BIN file download
v2.0.5 improment:
1. IFTTT function running locally
2. 4G SIM7600 GSM module for SMS, voice control , DTMF control way.
3. use tuya app by 4G if without ethernet or wifi.
4. digital input port support "OLD switch panel"
5. support DS18B20/DHT11/DHT22 sensor monitor.
6. support AUTOMATION with HTTP,TCP,RS232,RS485,UDP protocol to other devices.
7. relay output "momentary delay time" set be set longer.
8. fixed some bugs based "KCS v1" firmware.
9. support many new ESP32 board models.
10. something other updates.
.zip   KCS_KC868_A2_V2.0.5.zip (Size: 814.06 KB / Downloads: 947)
.zip   KCS_KC868_A4_V2.0.5.zip (Size: 804.81 KB / Downloads: 846)
.zip   KCS_KC868_A6_V2.0.5.zip (Size: 800.51 KB / Downloads: 772)
.zip   KCS_KC868_A8_V2.0.5.zip (Size: 808.14 KB / Downloads: 936)
.zip   KCS_KC868_A8M_V2.0.5.zip (Size: 825.43 KB / Downloads: 729)
.zip   KCS_KC868_A8S_V2.0.5.zip (Size: 827.08 KB / Downloads: 777)
.zip   KCS_KC868_A16_V2.0.5.zip (Size: 815.77 KB / Downloads: 756)
.zip   KCS_KC868_A16S_V2.0.5.zip (Size: 826.86 KB / Downloads: 738)
.zip   KCS_KC868_A32_V2.0.5.zip (Size: 809.59 KB / Downloads: 747)
.zip   KCS_KC868_A32M_V2.0.5.zip (Size: 828.11 KB / Downloads: 819)
.zip   KCS_KC868_A64_V2.0.5.zip (Size: 809.53 KB / Downloads: 892)
.zip   KCS_KC868_A128_V2.0.5.zip (Size: 809.7 KB / Downloads: 750)
.zip   KCS_KC868_AG_V2.0.5.zip (Size: 786.69 KB / Downloads: 742)
.zip   KCS_KC868_AI_V2.0.5.zip (Size: 811.87 KB / Downloads: 721)
.zip   KCS_KC868_AK_V2.0.5.zip (Size: 789.89 KB / Downloads: 818)
.zip   KCS_KC868_AM_V2.0.5.zip (Size: 801.33 KB / Downloads: 726)
.zip   KCS_KC868_ASR_V2.0.5.zip (Size: 776.8 KB / Downloads: 775)
.zip   KCS_KC868_E16S_V2.0.5.zip (Size: 811.91 KB / Downloads: 802)
.zip   KCS_KC868_UAIR_V2.0.5.zip (Size: 789.83 KB / Downloads: 827)
a minha a8 nao aceita salvar os inbut para acionar os outbut
can you take a video of your problem?
Hi! I have a KC868-AK and I updated to Firmware 2.05 (KCS), however I lost the options to customize input action with H32B-PRO. 1 click, 2 clicks and hold.
set IFTTT command by "DI" . now have more functions.
[Image: if-DI.png]
here is details of guide:
Thanks! I saw here how it works, as the H32B PRO works in RS 485 there is no need to send messages in the custom protocol. However, it is not possible to turn on or off more than one relay output of the controller. Correct?
H32B Pro support one command for turn ON/OFF/TOGGLE any relays .
So can I program IFTTT to do what the old firmware did: turn on any relay with one click, turn off another relay with two clicks?  And turn off all relays with the same button when hold. As per the figure:
you can create 3 IFTTT command by one digital input port. such as: DI-1 1-click actions, DI-1 2-click actions, DI-1 hold on actions.
And how do I make DI1 turn on outputs 1, 2 and 3 with 1 click and then turn off these outputs with 2 clicks?
