Node-Red-flows for KC868-Hx relay controller with AWS EC2 Cloud Server
Node-Red-flows for KC868-Hx relay controller, suit for KC868-H2,4,8,16,32 relay controller ,support old and new version of all relay controller.
.zip   KC868-Relay-Controller-AWS-EC2.zip (Size: 6.09 KB / Downloads: 975)
I have problem when I import.
Imported unrecognised types:
* ui_switch
* iu_group
* ui_tab
before import flows , you need install these nodes for Node-Red:
1. node-red-contrib-ui-led 【LED UI】
2. node-red-contrib-ui-level 【Temperature】
3. node-red-dashboard 【dashboard UI】
add KC868-H32 relay board input port monitor
.zip   KC868-Hx-relay-controller-switch-panel-input-port.zip (Size: 8.39 KB / Downloads: 906)
I'm getting an error message after installing , missing ui-base.
6 Apr 14:14:11 - [info] Waiting for missing types to be registered:
26 Apr 14:14:11 - [info]  - ui_base
What should I do?
(04-26-2021, 10:22 AM)Rhultin Wrote: Hi,
Everything fine, Reinstalled Dashboard Smile
What should I do?
take a screen photo.
I have imported the flow to node red, changed the IP address and port of the TCP nodes.
How can I get these switches on the dashboard?
(11-14-2022, 01:41 PM)filiperod Wrote: I have imported the flow to node red, changed the IP address and port of the TCP nodes.
oh, just realized that the relays on this flow are only visible on a node red dashboard, which I have no interest in creating. I would like to keep the switches on the main HA dashboard. I can control the relays on the relay board, but can't get feedback from the board when a switch is manually operated on the expansion board.
Is there a way to connect these two ends:
