KC868-A8M configure yaml for ESPhome
  platform: ESP32
remote_receiver:
  pin: 16
  dump:
    - rc_switch
  tolerance: 50%
  filter: 250us
  idle: 2ms
  buffer_size: 2kb
  sda: 5
  scl: 4
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  # Optional manual IP
  manual_ip:
    static_ip: 192.168.1.199
    gateway: 192.168.1.1
    subnet: 255.255.255.0
    address: 0x24
    address: 0x22
# Individual outputs
      pcf8574: pcf8574_hub_out_1
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
    on_press:
      then:
        - switch.toggle: light1
      pcf8574: pcf8574_hub_in_1
    on_press:
      then:
        - switch.toggle: light2
    on_press:
      then:
        - switch.toggle: light3
    on_press:
      then:
        - switch.toggle: light4
    on_press:
      then:
        - switch.toggle: relay5
      number: 4
    on_press:
      then:
        - switch.toggle: relay6
      number: 5
    on_press:
      then:
        - switch.toggle: relay7
      number: 6
    on_press:
      then:
        - switch.toggle: relay8
      number: 7
  - platform: remote_receiver
    rc_switch_raw:
      code: '000101000101010100000011'
      protocol: 2
    on_press:
      then:
    filters:
      - delayed_off: 200ms
    rc_switch_raw:
      code: '000101000101010100001100'
      protocol: 2
    on_press:
      then:
    filters:
    rc_switch_raw:
      code: '001111010111001010110100'
      protocol: 2
    on_press:
      then:
    filters:
    rc_switch_raw:
      code: '001111010111001010111001'
      protocol: 2
    on_press:
      then:
    filters:
    rc_switch_raw:
      code: '001111010111001010110010'
      protocol: 2
    on_press:
      then:
    filters:
    rc_switch_raw:
      code: '001111010111001010110101'
      protocol: 2
    on_press:
      then:
    filters:
    rc_switch_raw:
      code: '001111010111001010110001'
      protocol: 2
    on_press:
      then:
    filters:
    rc_switch_raw:
      code: '001111010111001010110011'
      protocol: 2
    on_press:
      then:
    filters:
.txt   KC868-A8M-ha-config.txt (Size: 5.68 KB / Downloads: 783)
Hello
i use your esp home example, but i get this error - see pic
it is like the adress for pcf8574 is wrong - i have two kc868-a8m it says the same error
take a photo how you connect wire with your A8M board.
(09-15-2023, 06:35 AM)admin Wrote: take a photo how you connect wire with your A8M board.
Hello
the board is only connectet with the usb cable, and an network cable. nothing else. i just upload your code. i tryed to change the code, to see if i get an new result. but no
se txt file
.txt   esphome.txt (Size: 6.53 KB / Downloads: 579)
you have not connect with dc12v power supply??
(09-15-2023, 08:11 AM)admin Wrote: you have not connect with dc12v power supply??
Sorry - yes power is on :-)
here is pic
your esphome LOG showed, have not detected i2c bus device. i suggest you download KCS v2 firmware to test control relay whether work well firstly.
here is details: https://www.kincony.com/esp32-kcsv2-firmware.html
if KCS firmware work well, then go to next step for check ESPHOME config.
Hello
sorry for the late reply, i deleted the code, and wrote it again - and so it works :-)
about the rf part, if i read an rf433 key, i get differnt codes everytime....
if i recive it in pronto format, i get the same code everytime :-)
so do you have and pice of esp home code, where i can use pronto code to trigger an light in esp, insted off raw code ?
what remote you have used?
suggest use "RC-switch" signal type for decode.
Hello itis an remote for my garage.
if i use rc_switch i get this
[07:30:57][D][remote.rc_switch:261]: Received RCSwitch Raw: protocol=1 data='0110110000100011101001101010001011010010101010111111111111111011'
[07:30:58][D][remote.rc_switch:261]: Received RCSwitch Raw: protocol=1 data='1110100100101100011000001000000011010010101010111111111111111'
[07:31:00][D][remote.rc_switch:261]: Received RCSwitch Raw: protocol=1 data='0111011101110001000110110111110111010010101010111111111111111011'
[07:31:01][D][remote.rc_switch:261]: Received RCSwitch Raw: protocol=1 data='01100111000001110010011110100001110100101'
[07:31:02][D][remote.rc_switch:261]: Received RCSwitch Raw: protocol=1 data='110000101001100111110101010011101101001010'
[07:31:03][D][remote.rc_switch:261]: Received RCSwitch Raw: protocol=1 data='0101100111001100010000100101010011010010101010111111111111111011'
[07:31:04][D][remote.rc_switch:261]: Received RCSwitch Raw: protocol=1 data='1011111101110001111100111011011111010010101010111111111111111011'
[07:31:05][D][remote.rc_switch:261]: Received RCSwitch Raw: protocol=1 data='1101001000010000011110111011001111010010101010111111111111111011'
[07:31:05][D][remote.rc_switch:261]: Received RCSwitch Raw: protocol=1 data='1100010110001010000000011110110111010010101010111111111111111011'
[07:31:06][D][remote.rc_switch:261]: Received RCSwitch Raw: protocol=1 data='0110010010000011010010011100010011010010101010111111111111111011'
[07:31:06][D][remote.rc_switch:261]: Received RCSwitch Raw: protocol=1 data='01100100100'
[07:31:07][D][remote.rc_switch:261]: Received RCSwitch Raw: protocol=1 data='0010101110000011100001111110000111010010101010111111111111111011'
[07:31:08][D][remote.rc_switch:261]: Received RCSwitch Raw: protocol=1 data='0010110010010101101111100000001011010010101010111111111111111011'
[07:31:09][D][remote.rc_switch:261]: Received RCSwitch Raw: protocol=1 data='100010000011011001000'
[07:31:10][D][remote.rc_switch:261]: Received RCSwitch Raw: protocol=1 data='11110011011000011110011101000000110100101'
and it is the same button !
