KC868-AIO configure yaml for ESPhome
.txt   KC868-AIO-ESPHome.txt (Size: 20.73 KB / Downloads: 1,883)
The ESPHome code shows Dallas on pin5.
dallas:
- pin: 5
update_interval: 60s
- platform: dallas
address: 0xec0921405caae128
Where does it connect on the board?
see photo. there are two GPIOs use for DS18B20.
Thank you.
you are welcome
Hello.  I need 62 inputs for my home automation (push buttons).  I can use the 56 digital inputs for that but I need 6 more, is it possible to use the analog input as digital input?
Thank you
sure, no problem, just connect with a voltage to analog input, such as 5v or 3.3v, because analog input range is dc 0-5v.
(04-06-2023, 01:01 AM)admin Wrote: sure, no problem, just connect with a voltage to analog input, such as 5v or 3.3v, because analog input range is dc 0-5v.
Thanks a lot
you are welcome
how can I use the SIM module with ESPhome?
