(10-08-2023, 09:27 AM)admin Wrote: can you change another power supply for a test? not use LED power supply.
I bought power supply that support recommended.
If it is connected to my circuit, then the indicators are as follows:
The voltage of the digital output without load is 22.5V.
When the relay is connected, the voltage is 8V.
If you pull the SSR out of the relay, the voltage is 12.7V.
Bad bad bad
