12-11-2023, 11:55 PM
- TV: How to extend controller with KinCony AG Pro ?
--> answer:
just integrate AP Pro to home assistant by wifi. then you can also use Tuya app remote control your IR devices. Multi controller can integrate to home assistant at the same time.
- Dimming lights: how to connect, extend Smart DB 32CH with KC868-D16 ?
--> answer:
make another DB for Dimmer controller -D16, add LED driver inside, we have video tour about it:
https://youtu.be/kmzjdaa85tA
CABLING:
a. Two boxes mean two smart controllers? Or I would have only a KC868-H32 Pro? If two controllers, how con I manage both as one ?
--> answer:
Yes, multi controller all connect to your router, they all integrate to home assistant, use by one software, different controller not need wire connect with each other, just only connect with ethernet cable to your router.
b. With one Smart DB 32CH, how many wall switches can I connect?
--> answer:
MAX 32 channel switch button. But sometime will have 2 or 3 buttons control one light, that cost 1 channel.
Do you have a basic cabling/wiring diagram of how to connect switches to Smart DB ?
--> answer:
see here , all diagram at here:
https://www.kincony.com/forum/forumdisplay.php?fid=33
Does one Wall Swich of 6 buttons count as ONE digital input?
--> answer:
need 6 digital input port, it connect with KC868-AK switch board, not connect to H32B Pro relay controller directly.
--> answer:
--> answer:
CABLING:
--> answer:
--> answer:
--> answer:
--> answer:
