12-18-2023, 11:13 PM
(12-18-2023, 11:09 PM)admin Wrote: can you post the newest yaml with latest KC868-HA component (v3.0.0).
friendly_name: dingtian-4ch
type: arduino
baud_rate: 0
encryption:
key: "XXX"
ota:
password: "XXX"
status_led:
number: GPIO15
uart:
tx_pin: GPIO1
rx_pin: GPIO3
baud_rate: 9600
type: JL1101
mdc_pin: GPIO23
mdio_pin: GPIO18
phy_addr: 0
clk_mode: GPIO17_OUT
# The PHY chip has a pin labeled TX_EN that goes to GPIO 21 on ESP
# and the RSTn pin on the phy goes to GPIO0
# Datasheet indicates the RSTn should be LOW to disable the phy and default is high
power_pin: GPIO0
external_components:
- source:
type: git
url: https://github.com/hzkincony/esphome-kc868-ha
ref: main
kc868_ha:
- platform: kc868_ha
target_relay_controller_addr: 1 # Default value is 1, corresponds to the Target Relay Controller Addr parameter in HA485_Ctrl software
switch_adapter_addr: 10 # Default value is 10, corresponds to the Switch Adapter Addr parameter in HA485_Ctrl software
bind_output: 1 # Corresponds to the BindOutput parameter in HA485_Ctrl software
bind_output: 2
bind_output: 3
bind_output: 4
bind_output: 5
bind_output: 6
bind_output: 1
bind_output: 2
bind_output: 3
bind_output: 4
bind_output: 5
bind_output: 6
