How use Serverboard IO from CM4
(12-18-2023, 12:25 AM)admin Wrote: "analog and digital inputs and outputs from Server Board" use ethernet MQTT work with CM4 (install mqtt broker on CM4 before).
Thankyou for answer!
Can you give me a link to an example, YouTube or forum entry, how can I read the analog input and describe an analog output?
At the moment the relay capacity is bothering me. I want 16A AC, or is there a version with field effect transistors so i can use more outputpin with 16A AC Relais?
RE: How use Serverboard IO from CM4 - by admin - 12-18-2023, 12:25 AM
RE: How use Serverboard IO from CM4 - by Helmut_number_one - 12-22-2023, 05:16 PM
RE: How use Serverboard IO from CM4 - by admin - 12-23-2023, 01:59 AM
RE: How use Serverboard IO from CM4 - by admin - 12-24-2023, 01:09 AM
