KC868-HA RS485 INPUT & OUTPUT plugin for ESPHome
#42
(12-25-2023, 08:02 AM)admin Wrote: when you turn ON/OFF a switch. check your ESPHome LOG. take a LOG screen photo and LOG file upload to here, let's check.
We send to see when you turn ON/OFF a switch, what package message have send out for RS485.
I have attached the ESPHome log output and the screenshot as requested.
In the log you will see that I turned on and off "Switch 1", then the same for "Switch 2". The LED's on the switches did not light up.
Then I pressed the physical button for "binary_sensor 6" input.
.txt   logs_dingtian-4ch_logs.txt (Size: 9.59 KB / Downloads: 510)
RE: KC868-HA RS485 INPUT & OUTPUT plugin for ESPHome - by gizmo - 12-25-2023, 01:11 PM
