Unable to Connect using the Application KC868-H32
Dear Kincony.
My COL and H32 boards are connected via WiFi. They are both connected via the RS232 cable. I have taken the screenshots but unable to display them on the page as such i have zip them up as attachment.
My issue is i am able to switch on the relay using the SCB Application but when i use the KC868-H32 application it does not work. Is my configuration on the VISCOM correct? I want to be able to switch relays on in the LAN environment and the WAN environment using either applications.
Also, when it comes necessary to run the SCB application i must be able to use that also especially if i want to use the IFTTT.
Please help
Regards
Subas
.zip   help.zip (Size: 946.73 KB / Downloads: 985)
Thank You
Regards
Subas
Unable to Connect using the Application KC868-H32 - by subas - 08-01-2021, 12:42 PM
