KC868-HA RS485 INPUT & OUTPUT plugin for ESPHome
#47
(01-13-2024, 12:47 AM)admin Wrote: This is really strange, other customers work well. if you really can't use, we can refund to you.
If other customers arent having an issue, then it must be either something with my set up.
I would much prefer to find the cause of the issue as I want to buy more of these items for my desired application.
The problem is I dont have much knowledge of RS485 applications, so was hoping to follow your guide and adjust as required. I have tried again by factory resetting the KC868-HAv2 and using your exact code for ESPhome as per your post https://github.com/hzkincony/esphome-kc868-ha.
From what I can see when I have the RS485 USB connected to a computer using the HA485 Assistant software, it doesnt show anything received when I toggle on the switch for the LED in Home Assistant. So I dont think that the command over RS485 is being sent, even though the ESPhome logs say it is.
How can I test this from a computer?
So I have just used another application called Serial Port Assistant https://github.com/KangLin/SerialPortAssistant and from that I can see data on the RS485 when I press a button connected to the KC868-HAv2, I can even copy that data string and send from the software and Home Assistant sees the button press the same.
However, when I turn on "Switch 1" in Home Assistant to toggle on the LED connected to the KC868-HAv2, ESPHome log outputs this " [23:22:45][D][uart_debug:114]: >>> 01:03:12:55:BB:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:01:30:4B", but I dont see that on the Serial Port Assistant software.
I will buy one of your KC868-A2 boards to test, maybe it is the board that I am using causing the problem.
RE: KC868-HA RS485 INPUT & OUTPUT plugin for ESPHome - by gizmo - 01-13-2024, 10:48 PM
