02-06-2024, 12:52 AM
1. MQTT command not support to check the target value. if you usually need change it, suggest config AUTOMATION by home assistant without KCS.
2.
i can switch off second fan from Home Assistant manualy.
But in IFTTT rules i have rule to start ALL FANS
-->second fan will ON when IFTTT works. if you want home assistant turn OFF, it's ok, because board will never disconnected with home assistant, will not lost with home assistant.
2.
