02-15-2024, 08:52 AM
(10-28-2022, 12:23 AM)admin Wrote: This is the error I get, I think it is happing when its compiling
Code:INFO ESPHome 2023.12.9
INFO Reading configuration /config/esphome/alarm-io.yaml...
WARNING GPIO5 is a strapping PIN and should only be used for I/O with care.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
INFO Generating C++ source...
INFO Compiling app...
Processing kc868-a8 (board: esp32dev; framework: arduino; platform: platformio/espressif32@5.4.0)
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
- toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
Dependency Graph
|-- WiFi @ 2.0.0
|-- ESPmDNS @ 2.0.0
|-- Wire @ 2.0.0
Compiling .pioenvs/kc868-a8/src/esphome/components/api/api_connection.cpp.o
Compiling .pioenvs/kc868-a8/src/esphome/components/api/api_frame_helper.cpp.o
xtensa-esp32-elf-g++: fatal error: Killed signal terminated program cc1plus
compilation terminated.
*** [.pioenvs/kc868-a8/src/esphome/components/api/api_frame_helper.cpp.o] Error 1
*** [.pioenvs/kc868-a8/src/esphome/components/api/api_connection.cpp.o] Error 1
========================== [FAILED] Took 4.11 seconds ==========================
I don't know what is causing it?
platform: ESP32
sda: 4
scl: 5
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
# Optional manual IP
manual_ip:
static_ip: 192.168.1.199
gateway: 192.168.1.1
subnet: 255.255.255.0
address: 0x24
address: 0x22
# Individual outputs
pcf8574: pcf8574_hub_out_1
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
pcf8574: pcf8574_hub_in_1
number: 4
number: 5
number: 6
number: 7
number: 32
number: 33
dallas:
- pin: 14
- platform: dallas
address: 0x1c0000031edd2a28
