02-21-2024, 01:01 PM
I'm sorry but I think i dind't explain my problem in the right way.
I've 2 kc868-a8 powered from the same power supply. So the ground is a common point for both card.
I connected several push buttons to each card. and I also connected 2 push bottons to both cards. I'd like to use the same push buttons to turn off a group on output. For those input, I'm using the analogs input of both card.
I meant...the same button is connected to both card!
The firmware is ok cause I can turn on lights with the buttons connected to digital inputs and I can turn off multiple lights when I press the button linked to ti analog inputs.
BUT!!! when I plug the connectors of analog input, I receive several signals as I pressed some buttons! The push buttons work properly! I just have this problem when I plug in the analog connectors!
