No Response
Exclamation
I have a KC868-A16S with the following code on it , After installing it it now will not respond,
the relays will only activate via the on board push button not via home assistant interface?
Home assistant show the switch turn on but the board does nothing.
I there any suggestion why this is happing ?
Dose the code look ok and can I reset the board and reload the firmware.
  friendly_name: ESPHome IO Board
    type: arduino
ota:
  safe_mode: true
  password: !sectet ota_password
  sda: 4
  scl: 5
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  # Optional manual IP
  manual_ip:
    static_ip: 192.168.1.3
    gateway: 192.168.1.1
    subnet: 255.255.255.0
    address: 0x24
    address: 0x25
    address: 0x21
    address: 0x22
# Individual outputs
      pcf8574: pcf8574_hub_out_1
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      number: 8
      mode: OUTPUT
      number: 9
      mode: OUTPUT
      number: 10
      mode: OUTPUT
      number: 11
      mode: OUTPUT
      number: 12
      mode: OUTPUT
      number: 13
      mode: OUTPUT
      number: 14
      mode: OUTPUT
      number: 15
      mode: OUTPUT
      pcf8574: pcf8574_hub_in_1
      inverted: false
      inverted: false
      inverted: false
      inverted: false
      number: 4
      inverted: false
      number: 5
      inverted: false
      number: 6
      inverted: false
      number: 7
      inverted: false
      pcf8574: pcf8574_hub_in_2
      number: 8
      inverted: false
      number: 9
      inverted: false
      number: 10
      inverted: false
      number: 11
      inverted: false
      number: 12
      inverted: false
      number: 13
      inverted: false
      number: 14
      inverted: false
      number: 15
      inverted: false
No Response - by Vaughan2024 - 04-27-2024, 08:54 AM
RE: No Response - by admin - 04-28-2024, 12:46 AM
RE: No Response - by Vaughan2024 - 04-28-2024, 11:29 AM
RE: No Response - by admin - 04-28-2024, 11:43 AM
