KC868-A16 home assistant demo configuration.yaml by MQTT
#11
the file is attached.
PS:  While trying to configure the HomeAssistant connection to the A16 in configuration.yaml, I also saw this message:
The esphome integration does not support configuration using a YAML file. You may not notice any obvious integration issues, but any settings defined in the YAML won't actually be applied. To solve this:
1. If you haven't already done so, set up the integration.
2. Remove "esphome:" from the YAML settings file.
3. Restart Home Assistant.
.txt   configuration-yam.txt (Size: 13.34 KB / Downloads: 697)
RE: KC868-A16 home assistant demo configuration.yaml by MQTT - by Brouk - 06-06-2024, 10:29 PM
