how to connect KC868 to home assistant
(03-26-2024, 06:04 PM)tamibandy Wrote:
(02-22-2024, 11:50 AM)Lucas35 Wrote: Connecting your KC868 to Home Assistant involves several steps. Here's a general guide, but keep in mind that specific details may vary based on your setup:
1.Connect KC868-A6 and nRF24l01 boards physically.
2.Configure KC868-A6 to connect to home Wi-Fi using a web interface or app.
3.Find the IP address of KC868-A6.
4.In Home Assistant's configuration file: switch:  - platform: kc868    host: YOUR_KC868_IP_ADDRESS
5.Restart Home Assistant.
6.Check and test the KC868-A6 switch in Home Assistant interface
Hope this helos, let me know how it goes Smile
Can you explain a little bit more detailed this steps?
I want to use KC868-A8.
What firmware should I use for the controller?
Thanks  Angel
I also need more info, i.e. on the step " 2.Configure KC868-A6 to connect to home Wi-Fi using a web interface or app.  "
I just received my KC868-A16 and can't get started with it. After powering up for the first time, I can't see the WiFi network, nor it doesn't connect automatically to my LAN. How to connect to it to start configuring the device?
RE: how to connect KC868 to home assistant - by jarekD - 06-16-2024, 08:05 PM
