Add KinCony modbus energy meter to home assistant using raspberry pi's RS485 port
#19
(08-01-2024, 12:38 AM)admin Wrote: change the meter parity: E
i have tested, only parity: E can use by home assistant.
Check screenshot. I also see 0.04 kwh in the config tool. Could the enery meter be damaged?
After setting Parity to EVEN and updating yaml now I'm having this error in Home Assistant: Pymodbus: hub1: Error: device: 1 address: 100 -> Modbus Error: [Input/Output] Modbus Error: [Invalid Message] No response received, expected at least 4 bytes (0 received)
RE: Add KinCony modbus energy meter to home assistant using raspberry pi's RS485 port - by sebagarayco - 08-01-2024, 01:29 AM
