how to use binary sensor make VOICE CALL by SIM7600E 4G module in ESPHome
the ESPHome yaml demo made for KinCony KC868-A8S relay board. Actually you can use for any KinCony SIM7600 relay board, just replace 4G module's TXD,RXD define.
here is ESPHome yaml demo:
  platform: ESP32
  sda: 4
  scl: 5
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
    address: 0x24
    address: 0x22
# Individual outputs
      pcf8574: pcf8574_hub_out_1
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
    interlock: [relay6]
      number: 4
      mode: OUTPUT
    interlock: [relay5]
      number: 5
      mode: OUTPUT
    interlock: [relay8]
      number: 6
      mode: OUTPUT
    interlock: [relay7]
      number: 7
      mode: OUTPUT
# UART configuration for SIM7600E
uart:
  tx_pin: GPIO13
  rx_pin: GPIO15
  baud_rate: 115200
  debug:
    direction: BOTH
    dummy_receiver: true
    after:
      timeout: 10ms
    sequence:
    on_press:
      then:
        - uart.write:
            data: "ATD15381188302;\r\n"  # Replace with the phone number you want to dial
      pcf8574: pcf8574_hub_in_1
    on_press:
      then:
        - switch.toggle: light2
    on_press:
      then:
        - switch.toggle: light3
    on_press:
      then:
        - switch.toggle: light4
    on_press:
      then:
        - switch.toggle: relay5
      number: 4
    on_press:
      then:
        - switch.toggle: relay6
      number: 5
    on_press:
      then:
        - switch.toggle: relay7
      number: 6
    on_press:
      then:
        - switch.toggle: relay8
      number: 7
web_server:
  port: 80
download yaml file:
.txt   KC868-A8S-HA-INPUT-SIM7600-CALL.txt (Size: 4.03 KB / Downloads: 402)
how to use binary sensor make VOICE CALL by SIM7600E 4G module in ESPHome - by admin - 08-28-2024, 12:58 AM
