PZEM-004T With A6 on Serial
Howdy!
Thanks for the A6 Board, im using the second one already and i enjoy it.
I encountered a problem, connected PZEM-004T to Serial on A6 (GPIO12, 13)
When i power the board, it doesnt boot. I plug out the PZEM-004T from A6, it boots. I plug pzem back in. It works normaly, and i receive all the needed data.
What is the problem i have on boot?
pastebin code:
https://pastebin.com/Rbujh2R1
code:
friendly_name: KotelA6
libraries:
- "Wire"
- "ArduinoJson"
type: arduino
wifi:
ssid: !secret wifi_ssid
encryption:
key:
captive_portal:
ota:
password: "
uart:
- id: ubus1
tx_pin: GPIO13
rx_pin: GPIO12
baud_rate: 9600
stop_bits: 1
sda: GPIO4
scl: GPIO15 # Change SCL to GPIO22 to avoid issues with GPIO15
address: 0x24
- id: 'pcf8574_hub_in_1' # for input channel 9-16
address: 0x22
pcf8575: false
time:
- platform: ds1307
#### PZEM-004T V3 ####
- platform: pzemac
address: 1
current:
accuracy_decimals: 2
voltage:
power:
unit_of_measurement: W
frequency:
unit_of_measurement: Hz
power_factor:
energy:
unit_of_measurement: Wh
accuracy_decimals: 1
update_interval: 5s
- platform: template
unit_of_measurement: "kWh"
update_interval: 5s
icon: mdi:power
lambda: return (( (id(pMeter_energy).state)/1000.0));
- platform: total_daily_energy
power_id: pMeter_power
filters:
# Multiplication factor from W to kW is 0.001
- multiply: 0.001
icon: mdi:counter
unit_of_measurement: "kwh"
icon: mdi:power
update_interval: 10s
unit_of_measurement: "VA"
icon: mdi:power
lambda: return ( (id(pMeter_power).state/id(pMeter_power_factor).state));
unit_of_measurement: "VAr"
icon: mdi:power
lambda: return ( ( sqrt( (id(pMeter_power_apparente).state)*(id(pMeter_power_apparente).state) - (id(pMeter_power).state)*(id(pMeter_power).state) ) ) );
- platform: wifi_signal
name: "WiFi power_pMeter"
- platform: uptime
text_sensor:
lambda: |-
int seconds = (id(uptime_sec).state);
int days = seconds / (24 * 3600);
seconds = seconds % (24 * 3600);
int hours = seconds / 3600;
seconds = seconds % 3600;
int minutes = seconds / 60;
seconds = seconds % 60;
return { (String(days) +"d " + String(hours) +"h " + String(minutes) +"m "+ String(seconds) +"s").c_str() };
icon: mdi:clock-start
update_interval: 113s
################################################# SENSOR
- platform: status
icon: mdi:home-flood
pcf8574: pcf8574_hub_in_1
number: 4
number: 5
################################################# RELAYS
- platform: restart
### KINCONY 1
icon: mdi:fan
pcf8574: pcf8574_hub_out_1
mode: OUTPUT
mode: OUTPUT
########################### ######### BOILER PUMP
icon: mdi:pump
mode: OUTPUT
################################## #RECIRCULATE
icon: mdi:pump
mode: OUTPUT
######################## INTERLOCK WATER STOP ###########################
icon: mdi:water-off-outline
number: 4
mode: OUTPUT
interlock: [relay_6] # Interlock with Grow Pump_6
icon: mdi:water
number: 5
mode: OUTPUT
interlock: [relay_5]
restore_mode: ALWAYS_ON
PZEM-004T With A6 on Serial - by Techno - 09-02-2024, 01:56 PM
RE: PZEM-004T With A6 on Serial - by mikesloper - 09-02-2024, 03:19 PM
RE: PZEM-004T With A6 on Serial - by Techno - 09-02-2024, 06:31 PM
RE: PZEM-004T With A6 on Serial - by mikesloper - 09-03-2024, 01:37 PM
RE: PZEM-004T With A6 on Serial - by admin - 09-03-2024, 06:13 AM
RE: PZEM-004T With A6 on Serial - by mikesloper - 09-03-2024, 01:25 PM
RE: PZEM-004T With A6 on Serial - by Techno - 09-03-2024, 01:41 PM
RE: PZEM-004T With A6 on Serial - by admin - 09-03-2024, 11:47 PM
RE: PZEM-004T With A6 on Serial - by Techno - 09-12-2024, 05:52 PM
RE: PZEM-004T With A6 on Serial - by admin - 09-13-2024, 12:11 AM
RE: PZEM-004T With A6 on Serial - by wanball - 05-20-2025, 09:28 AM
RE: PZEM-004T With A6 on Serial - by admin - 05-20-2025, 11:11 PM
